0009068 | VTK | (No Category) | public | 2009-05-26 14:39 | 2016-08-12 09:55 | ||||
Reporter | ppeetteerr | ||||||||
Summary | 0009068: vtkPolyDataConnectivityFilter() doesn't filter data when passed to out using vtk_to_numpy | ||||||||
Description | I'm not sure whether this is a vtkPolyDataConnectivityFilter() or a vtk_to_numpy issue, I assume the latter. vtkPolyDataConnectivityFilter() succesfully filters the data when rendering the data or writing the data to an stl. However when I use vtk_to_numpy the surronding regions are passed as well. The odd thing is that some of the regions are filtered. I can tell this by running size. In the example below SetExtractionModeToLargestRegion() eliminates some of the data (size(ar) shrinks from 618 to 597) Using a standardized dataset the code is below import vtk import vtk.util.numpy_support as VN from pylab import * reader = vtk.vtkRectilinearGridReader() reader.SetFileName('.\RectGrid2.vtk') skinExtractor = vtk.vtkContourFilter() skinExtractor.SetInputConnection(reader.GetOutputPort()) skinExtractor.SetValue(0, 5.2) skinConnect=vtk.vtkPolyDataConnectivityFilter() skinConnect.SetInputConnection(skinExtractor.GetOutputPort()) skinConnect.SetExtractionModeToLargestRegion() skinNormals = vtk.vtkPolyDataNormals() skinNormals.SetInputConnection(skinConnect.GetOutputPort()) skinNormals.SetFeatureAngle(60.0) skinMapper = vtk.vtkPolyDataMapper() skinMapper.SetInputConnection(skinNormals.GetOutputPort()) skinMapper.ScalarVisibilityOn() skinMapper.SetColorModeToMapScalars() skinMapper.SelectColorArray('scalars') skinActor = vtk.vtkActor() skinActor.SetMapper(skinMapper) skinu = skinNormals.GetOutput() # Force the pipeline to execute skinu.Update() ar = VN.vtk_to_numpy(skinu.GetPoints().GetData()) #print ar temp=[] for item in ar: if item[2]>0.899999: temp+=[item] temp=array(temp) x1=temp[:,0] y1=temp[:,1] scatter(x1,y1) show() ren = vtk.vtkRenderer() ren.AddActor(skinActor) renWin = vtk.vtkRenderWindow() renWin.AddRenderer(ren) iren = vtk.vtkRenderWindowInteractor() iren.SetRenderWindow(renWin) ren.ResetCamera() renWin.Render() iren.Initialize() iren.Start() ========================================= | ||||||||
(0037079) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2009-05-26 14:39 | ppeetteerr | New Issue | |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037079 | |
2016-08-12 09:55 | Kitware Robot | Status | expired => closed |
2016-08-12 09:55 | Kitware Robot | Resolution | open => moved |
2016-08-12 09:55 | Kitware Robot | Assigned To | => Kitware Robot |
