0009028 | ParaView | Bug | public | 2009-05-14 09:03 | 2013-05-18 20:00 | ||||
Assigned To | Marcus D. Hanwell | ||||||||
Target Version | NeedsVerification | Fixed in Version | 4.0 | ||||||
Summary | 0009028: Plots interpolate to invalid points | ||||||||
Description | The Plot Over Line filter creates a special column in its output called vtkValidPointMask that is a flag to the plot view to specify that the given point has no data and therefore should not be drawn. When the point is invalid, the rest of the columns are filled with zero for no particular consequence since these values will not be viewed. (Should they have NAN instead?) The problem is that in the XY plot when you have a valid point next to an invalid point, it interpolates between the valid point. This creates inappropriate lines to the 0 axis. To see this problem in action, do the following. 1. Load disk_out_ref.ex2, load Temp variable, Apply. 2. Note that the range of Temp goes from 293 to 913. This is in Kelvins, so it never gets near zero. 3. Plot Over Line. Apply. The default line for the plot starts outside the mesh, goes inside, back outside, back inside, and then outside for a final time. This is reflected by the two distinct regions in the plot. However, notice that at the ends of each contiguous region there is a line drawn down to 0. Those lines should not be there. The data never goes to 0 and therefore we should not be drawing lines to 0. | ||||||||
Project | Sandia | ||||||||
(0016733) Julien Finet (developer) 2009-06-17 08:14 edited on: 2009-06-17 10:51 |
The inappropriate lines to the X axe are not an interpolation problem. It is just that invalid points are not handled by charts. Valid and invalid points are systematically drawn. |
(0025139) Marcus D. Hanwell (developer) 2011-01-28 14:02 |
It seems to me that we should make these NaN, and then I could improve the charts to handle NaN correctly. Or, is there some reason that you would want to distinguish between invalid points and true NaN? |
(0025176) Ken Moreland (manager) 2011-01-31 10:03 |
I think using NaN as the identifier for invalid points is perfectly fine. All the NaNs I've seen in real data so far have been used to signify "invalid" or "no data". We were also proposing the use of NaN instead of the vtkValidPointMask to plot multiple series where each series may have different sets of valid values (for example if plotting a line over multiblock data with different fields in different blocks). |
(0025177) Marcus D. Hanwell (developer) 2011-01-31 10:11 |
That is good to hear, and the NaN solution seems more flexible than the valid point mask which would affect all rows. I also think the solution using NaNs would be more generally useful to the VTK community outside of ParaView. I will try to complete this work (I already have a list of invalid points in any particular plot in order to find a valid range - extending it to build up multiple lines is the next logical step). |
(0025179) Ken Moreland (manager) 2011-01-31 10:29 |
Be careful because NaN is not fully supported by VTK. I've pushed to have NaN be used in some parts of ParaView and have updated some small parts of VTK to handle NaNs better. However, almost all filters in VTK have no concept of NaN and some will freak out when they get one. Anyway, I guess my point is that you should have a conversation with Berk before implementing this. I support the use of NaNs but he might have a second opinion. |
(0025180) Marcus D. Hanwell (developer) 2011-01-31 10:34 |
I think in the case of charts it is a little simpler - they are end consumers of the numbers (nothing beyond them in a pipeline). There has been code to handle NaNs, infinity etc for over a year now I think. I was just going to extend this into the rendering routines a little further, there are already a couple of bugs due to inconsistent handling of NaNs by OpenGL implementations - stopping the NaNs getting that far should fix those issues. I will get a second opinion to see if there is anything I missed though. |
(0030691) Utkarsh Ayachit (administrator) 2013-05-03 14:03 |
I believe this is already fixed. |
(0030743) Utkarsh Ayachit (administrator) 2013-05-10 08:23 |
SUMMARY --------------------------------------------- Topics merged into master: 13853_catalyst_immediate_mode_rendering2 13981_fix_install_rules 13991_fix_window_sizes 14040_add_save_animation_time_range_v2 14046_fix_selection_issues 14058_fix_camera_animation_in_parallel_scale 14059-vtkPVGeometryFilter-unnecessary-array fix-custom-view-button-leak fix-multi-block-issues fix_pointsprite_plugin gmv-test-cleanup pvw-add-exit-button |
(0030769) Alan Scott (manager) 2013-05-15 13:29 |
Tested master, Linux, remote server. I also tried running the output of the plot over line filter into a spreadsheet. It worked with the NAN's. I sorted the spreadsheet, and the NAN's didn't sort correctly. But, that is another bug. |
2009-05-14 09:03 | Ken Moreland | New Issue | |
2009-06-03 10:34 | Utkarsh Ayachit | Status | backlog => tabled |
2009-06-03 10:34 | Utkarsh Ayachit | Assigned To | => Julien Finet |
2009-06-17 08:14 | Julien Finet | Note Added: 0016733 | |
2009-06-17 10:51 | Julien Finet | Note Edited: 0016733 | |
2011-01-28 13:54 | Utkarsh Ayachit | Assigned To | Julien Finet => Marcus D. Hanwell |
2011-01-28 13:54 | Utkarsh Ayachit | Target Version | 3.8 => NeedsVerification |
2011-01-28 14:02 | Marcus D. Hanwell | Note Added: 0025139 | |
2011-01-31 10:03 | Ken Moreland | Note Added: 0025176 | |
2011-01-31 10:11 | Marcus D. Hanwell | Note Added: 0025177 | |
2011-01-31 10:29 | Ken Moreland | Note Added: 0025179 | |
2011-01-31 10:34 | Marcus D. Hanwell | Note Added: 0025180 | |
2013-01-08 21:31 | Alan Scott | Project | => Sandia |
2013-01-08 21:31 | Alan Scott | Type | => incorrect functionality |
2013-05-03 14:03 | Utkarsh Ayachit | Note Added: 0030691 | |
2013-05-03 14:03 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-05-03 14:03 | Utkarsh Ayachit | Resolution | open => fixed |
2013-05-10 08:23 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-05-10 08:23 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-05-10 08:23 | Utkarsh Ayachit | Note Added: 0030743 | |
2013-05-15 13:29 | Alan Scott | Note Added: 0030769 | |
2013-05-15 13:29 | Alan Scott | Status | customer review => closed |
2013-05-18 20:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.0 |
