0008964 | ParaView | (No Category) | public | 2009-05-05 12:59 | 2009-06-03 20:35 | ||||
Reporter | David Doria | ||||||||
Target Version | Fixed in Version | 3.6 | |||||||
Summary | 0008964: Bad default glyph size | ||||||||
Description | If I open a small model (bounding box edge length about .1) and add vector glyphs of the normals, the "scale factor" changes to 397794.090337098 and hence the arrows are ENORMOUS and it makes the model look like a single point. If I check "Edit", change the scale factor to .1, and hide then show the model (to reset the zoom), it looks correct. | ||||||||
Attached Files | Scene.vtp [^] (34,727 bytes) 2009-05-05 12:59 | ||||||||
Relationships | ||||||
(0016591) Utkarsh Ayachit (administrator) 2009-05-29 11:08 |
Why in the world were we taking the different of magnitudes when computing scale factor? We just needed to consider the maximum value. This was resulting in humungous scale factors when differences between vector values were small. Fixed that. /cvsroot/ParaView3/ParaView3/Qt/Components/pqGlyphPanel.cxx,v <-- Qt/Components/pqGlyphPanel.cxx new revision: 1.9; previous revision: 1.8 * Pending commit to 3.6 branch |
(0016624) Alan Scott (manager) 2009-06-03 20:18 |
I think I am going to fix this, since it is MUCH better with this fix. However, we have still not fixed the underlying problem (using time 0 for ranges, as opposed to taking something better like the last time). This fix will only work if time step 0 has reasonable numbers in it such as velocity. It won't work if time step 0 has initial conditions, such as displacement. This bigger problem is documented in bug number 5659. Tested local client, using can.exo. |
(0016625) Utkarsh Ayachit (administrator) 2009-06-03 20:18 |
Committed to 3.6 on May 29. |
(0016626) Alan Scott (manager) 2009-06-03 20:33 |
Trying to form relationships. This is a test. |
(0016627) Alan Scott (manager) 2009-06-03 20:35 |
Getting a relationship to work. Closing again. |
2009-05-05 12:59 | David Doria | New Issue | |
2009-05-05 12:59 | David Doria | File Added: Scene.vtp | |
2009-05-29 11:08 | Utkarsh Ayachit | Note Added: 0016591 | |
2009-05-29 11:08 | Utkarsh Ayachit | Status | backlog => @80@ |
2009-05-29 11:08 | Utkarsh Ayachit | Fixed in Version | => 3.6 |
2009-05-29 11:08 | Utkarsh Ayachit | Resolution | open => fixed |
2009-05-29 11:08 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-06-03 20:18 | Alan Scott | Note Added: 0016624 | |
2009-06-03 20:18 | Alan Scott | Status | @80@ => closed |
2009-06-03 20:18 | Utkarsh Ayachit | Note Added: 0016625 | |
2009-06-03 20:33 | Alan Scott | Note Added: 0016626 | |
2009-06-03 20:33 | Alan Scott | Status | closed => tabled |
2009-06-03 20:34 | Alan Scott | Relationship added | related to 0005659 |
2009-06-03 20:35 | Alan Scott | Note Added: 0016627 | |
2009-06-03 20:35 | Alan Scott | Status | tabled => closed |
