0008762 | ParaView | Bug | public | 2009-03-19 06:35 | 2016-08-12 09:57 | ||||
Reporter | Sven Buijssen | ||||||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Target Version | Someday | Fixed in Version | |||||||
Summary | 0008762: Color not updated in "Set Solid Color" button when changing color settings | ||||||||
Description | Sources - Box Display tab - Color by Solid color - Set Solid Color to Foreground Now change foreground color settings via "Edit - Settings - Colors - Foreground Color". Click Apply, then Ok. Notice that the 3D render view is correctly updated, so is the color in the bullet before "Foreground Color" in the "Set Solid Color" drop-down chooser. But the color of the bullet to the left in the "Set Solid Color" button itself has not been updated. tested with CVS build last night (Mar/19/2009), Linux-g++-ompi | ||||||||
(0015731) Ken Moreland (manager) 2009-03-19 08:59 |
If it's easy to fix then do it. Otherwise, we can close it as a "won't fix". |
(0037633) Kitware Robot (administrator) 2016-08-12 09:57 |
2009-03-19 06:35 | Sven Buijssen | New Issue | |
2009-03-19 08:59 | Ken Moreland | Note Added: 0015731 | |
2009-03-19 08:59 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
2009-03-19 08:59 | Ken Moreland | Priority | normal => low |
2009-03-19 08:59 | Ken Moreland | Status | backlog => tabled |
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
2009-08-25 12:03 | Ken Moreland | Category | => Bug |
2009-08-25 12:03 | Ken Moreland | Target Version | 3.6 => 3.6.2 |
2009-10-01 16:07 | Utkarsh Ayachit | Target Version | 3.6.2 => Someday |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037633 | |
