0008683ParaView(No Category)public2009-03-06 11:222010-12-14 09:38
ReporterKen Moreland
Assigned ToMarcus D. Hanwell
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target Version3.10Fixed in Version3.10
Summary0008683: Axes in charts rescale by default when animating over time
DescriptionWhen you are plotting some data that changes over time in a bar chart or x-y plot, the axes by default will readjust at every time step if the ranges change. A better default behavior would be to hold them steady to prevent misleading changes in the plot. Basically, the behavior should follow that of the color map in 3D views.
TagsNo tags attached.
Project
Topic Name
Type
 Relationships
related to 0008687closed Reset range for chart axes
child of 0008596closedUtkarsh Ayachit (Venus - Medium) Ability to set time series plots with data from all time steps
  Notes
(0023214)
Dave DeMarle (administrator)
2010-11-12 14:01
Marcus please verify that the chart ranges work like colormaps do: fixed to first known, or user specified range.
(0023233)
Marcus D. Hanwell (developer)
2010-11-12 20:32
I didn't see the message as you didn't assign this to me - I can confirm the current behavior is as Ken states. User specified ranges are kept, but when animating the chart is rescaled at each time step.
(0023809)
2010-12-08 13:53
This should now be fixed with commit b1d3d35 - please let me know if it does not conform to your requirements.
(0023949)
Ken Moreland (manager)
2010-12-14 09:38
Verified local connection.
 Issue History
2009-03-06 11:22 Ken Moreland New Issue
2009-03-06 11:23 Ken Moreland Relationship added child of 0008596
2009-03-06 11:35 Ken Moreland Relationship added related to 0008687
2009-05-13 13:39 Utkarsh Ayachit Target Version => 3.8
2010-11-12 14:01 Dave DeMarle Note Added: 0023214
2010-11-12 20:30 Marcus D. Hanwell Assigned To => Marcus D. Hanwell
2010-11-12 20:30 Marcus D. Hanwell Status backlog => tabled
2010-11-12 20:32 Marcus D. Hanwell Note Added: 0023233
2010-12-06 16:15 Marcus D. Hanwell Target Version 3.8 => 3.10
2010-12-08 13:53 Marcus D. Hanwell Note Added: 0023809
2010-12-08 13:53 Marcus D. Hanwell Status tabled => @80@
2010-12-08 13:53 Marcus D. Hanwell Fixed in Version => 3.10
2010-12-08 13:53 Marcus D. Hanwell Resolution open => fixed
2010-12-14 09:38 Ken Moreland Note Added: 0023949
2010-12-14 09:38 Ken Moreland Status @80@ => closed
