0008597 | ParaView | (No Category) | public | 2009-02-24 13:55 | 2009-05-15 19:10 | ||||
Target Version | 3.6 | Fixed in Version | 3.6 | ||||||
Summary | 0008597: (Venus - High) Pipeline not updating correctly | ||||||||
Description | Local server, XP, ParaView trunk. Open Can.exo. Calculator. Equation VEL*100, Result Array Name Vel100. Apply. Filters/ Data Analysis/ Plot over line filter. Select calculator. Filters/ Data Analysis/ Plot over line filter.(this step is probably not necessary) Select can.exo. Calculator. Equation ACCL*100, Result Array Name Accl100. Apply. Select Calculator 1. Change Input. Change input to be Calculator 2. We have now inserted another calculator into the pipeline. But, notice that Accl100 never shows up in the plots! This is a bug - the pipeline, and the plots, are not resetting. | ||||||||
(0015513) Utkarsh Ayachit (administrator) 2009-03-03 10:27 |
This seems to have been fixed with the new charts. When the input of the plot-over-line filter is changed, the new plots are immediately updating to show the new arrays. Leaving this open till the new plots become the default plots. |
(0016457) Utkarsh Ayachit (administrator) 2009-05-14 20:54 |
Ensure that all views are rendered when input is changed. /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineBrowser.cxx,v <-- Qt/Components/pqPipelineBrowser.cxx new revision: 1.28; previous revision: 1.27 |
(0016494) Alan Scott (manager) 2009-05-15 19:10 |
Wow, I wrote a poor bug report. Tested local server. |
2009-02-24 13:55 | Alan Scott | New Issue | |
2009-02-26 17:45 | Alan Scott | Summary | Pipeline not updating correctly => (Venus - High) Pipeline not updating correctly |
2009-03-02 20:23 | Alan Scott | Priority | normal => high |
2009-03-02 20:26 | Alan Scott | Category | 3.8 => 3.6 |
2009-03-03 10:27 | Utkarsh Ayachit | Note Added: 0015513 | |
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
2009-05-14 20:54 | Utkarsh Ayachit | Note Added: 0016457 | |
2009-05-14 20:54 | Utkarsh Ayachit | Status | backlog => @80@ |
2009-05-14 20:54 | Utkarsh Ayachit | Fixed in Version | => 3.6 |
2009-05-14 20:54 | Utkarsh Ayachit | Resolution | open => fixed |
2009-05-14 20:54 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-05-15 19:10 | Alan Scott | Note Added: 0016494 | |
2009-05-15 19:10 | Alan Scott | Status | @80@ => closed |
