0008497 | ParaView | (No Category) | public | 2009-02-10 20:03 | 2009-05-13 14:05 | ||||
Status | closed | Resolution | not fixable | ||||||
Target Version | 3.6 | Fixed in Version | 3.6 | ||||||
Summary | 0008497: Multiple processor restart files don't work | ||||||||
Description | Multiple processor restart files don't work. Single processor restart files do. Enclosed are single processor restart files and multiple processor restart files. This must be fixed for 3.6. | ||||||||
Attached Files | singleProcessorRestartExample.zip [^] (115,294 bytes) 2009-02-10 20:03 multipleProcessorRestartExample.zip [^] (219,931 bytes) 2009-02-10 20:04 multipleProcessorRestartExampleGood.zip [^] (225,241 bytes) 2009-02-16 21:54 | ||||||||
(0014896) Ken Moreland (manager) 2009-02-11 11:28 |
This is not a problem with the reader as reported. Rather, this is a problem with the data in the attached multipleProcessorRestartExample.zip file. Look carefully at the time values for the exampleRestart.e-s.0002.2.* files. The have values that range 0-6 when in fact they should range 3-9 (as the time values in restartFiles.e-s.000 do). Because the time values in the data are wrong, it is impossible for the restart reader to resolve the appropriate time step to load (the old computer adage "garbage in, garbage out"). Fix the time step values in exampleRestart.e-s.002.2.* and it should work just fine. |
(0015007) Alan Scott (manager) 2009-02-16 21:52 |
Correcting the multiple processor file example. |
(0015008) Alan Scott (manager) 2009-02-16 21:54 |
The zip file that shows the problem is multipleProcessorRestartExampleGood.zip (meaning correct files, not correct behavior) |
(0015031) Alan Scott (manager) 2009-02-17 13:16 |
I tried running the multiple block dataset (attached), and it seems to have the time steps loaded correctly, but puts out the following errors: Warning: In ..\..\..\..\src\ParaView3\VTK\Hybrid\vtkExodusIIReader.cxx, line 6003 vtkPExodusIIReader (0B060BD8): No arrays named "thickness" of the specified type (14). Warning: In ..\..\..\..\src\ParaView3\VTK\Hybrid\vtkExodusIIReader.cxx, line 5079 vtkExodusIIReaderPrivate (0B061328): You requested array -1 in a collection of only 2 arrays. Warning: In ..\..\..\..\src\ParaView3\VTK\Hybrid\vtkExodusIIReader.cxx, line 5894 vtkPExodusIIReader (0B060BD8): No objects named "Unnamed block ID: 9 Type: quad Size: 129" of the specified type (1). Warning: In ..\..\..\..\src\ParaView3\VTK\Hybrid\vtkExodusIIReader.cxx, line 2760 vtkExodusIIReaderPrivate (0B061328): You requested Element block -1 in a collection of only 2 objects. |
(0015033) Ken Moreland (manager) 2009-02-17 13:19 |
The problem is again in the data set. Now the time values are right, but the variable names are wrong. In the first data set, the variable names are in lower case. In the second data set, the variable names are in upper case. The errors you are getting are from the assumption that all data sets have the same variables with the same names. |
(0015097) Alan Scott (manager) 2009-02-17 19:41 |
Sounds correct to me. Grrr - the dataset was made from the same source, and the tools I used changed the case of the variables. Nuts. Tested Client/Server on numerous pvservers. |
2009-02-10 20:03 | Alan Scott | New Issue | |
2009-02-10 20:03 | Alan Scott | File Added: singleProcessorRestartExample.zip | |
2009-02-10 20:04 | Alan Scott | File Added: multipleProcessorRestartExample.zip | |
2009-02-11 09:17 | Ken Moreland | Status | backlog => tabled |
2009-02-11 09:17 | Ken Moreland | Assigned To | => Ken Moreland |
2009-02-11 11:28 | Ken Moreland | Note Added: 0014896 | |
2009-02-11 11:28 | Ken Moreland | Status | tabled => @80@ |
2009-02-11 11:28 | Ken Moreland | Resolution | open => not fixable |
2009-02-16 21:52 | Alan Scott | Note Added: 0015007 | |
2009-02-16 21:52 | Alan Scott | Status | @80@ => tabled |
2009-02-16 21:54 | Alan Scott | File Added: multipleProcessorRestartExampleGood.zip | |
2009-02-16 21:54 | Alan Scott | Note Added: 0015008 | |
2009-02-17 13:16 | Alan Scott | Note Added: 0015031 | |
2009-02-17 13:19 | Ken Moreland | Note Added: 0015033 | |
2009-02-17 13:19 | Ken Moreland | Status | tabled => @80@ |
2009-02-17 16:52 | Utkarsh Ayachit | Category | 3.6 => Pending |
2009-02-17 19:41 | Alan Scott | Note Added: 0015097 | |
2009-02-17 19:41 | Alan Scott | Status | @80@ => closed |
2009-05-13 14:05 | Utkarsh Ayachit | Target Version | => 3.6 |
2009-05-13 14:05 | Utkarsh Ayachit | Fixed in Version | => 3.6 |
