0008422ParaViewBugpublic2009-01-22 18:272011-01-13 17:00
ReporterAlan Scott
Assigned ToUtkarsh Ayachit
PriorityhighSeverityfeatureReproducibilityalways
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target Version3.6.2Fixed in Version3.6.2
Summary0008422: Need implicit exodus node index in selection view
DescriptionHere is a request from a user. I think he makes more sense than I do, so I am copying what he said. There is a dataset associated with this request, ask me for it. (blade1_full.exo)
We need to be able to ascertain the exodus node number even in the presence of a node map. The attached file has two important node numbers associated with each node:
  1. The exodus node index, which is implicitly numbered (1:N) on the model.
It is used for all connectivity information.
  2. The global node id.
The situation is slightly different in parallel and serial. I will explain with an example. The attached example has a beam sticking out of the end of the blade. The last node on that beam is the 303 node in the exodus file.
It's global ID is 4800705. The "selection inspector" properly reports its global node id (or pedigree id). Both the global node id and pedigree id are the same in version 3.4.0. However, it's point id has no connection to anything in the exodus model. The point id is zero.
The underlying exodus file lists this as the 303 node in the model. The 303rd entry in the node number map is 4800705. Thus, paraview knows the index and is associating the proper node id with the node, but it does not report the index of 303. This index is used in various other places, most importantly in the connectivity table. The connectivity for element block 480000 contains this index as is shown by grope.
GROPE> sele block 480000
GROPE> list connecti
 Block***** (#2): 6 elements (3..8) 2-node 7 attributes
      # elem Connectivity
       1 3 303 304
       2 4 304 66
       3 5 66 67
       4 6 67 65
       5 7 65 64
       6 8 64 39
The same information can be seen (in another format) in the exodus file using either exotxt or ncdump. I can provide those if needed.
In parallel we need the same data, but the meaning is slightly different. In parallel, the node number map of the spread files points to the original exodus data numbering. Thus, in parallel (I believe) paraview will now return the number 303 for the global id. This is as it should be. But, now on the local subdomain, we should still be able to find the local exodus index which would depend of course on the decomposition.
I would suggest these values be labeled as follows.
global id should return the same data it currently does.
local id should return the index, i.e. 303 for the serial case.
TagsNo tags attached.
Project
Topic Name
Type
has duplicate 0009341closed Implicit Node/Element Indices from Exodus Files
related to 0009649closedUtkarsh Ayachit Get Exodus implicit index arrays to work with the Selection Inspector
-  Notes
(0017185)
Ken Moreland (manager)
2009-08-24 13:20
I think this bug boils down to writing out special arrays for the implicit node and element indices (similar to the global indices or object ids). The data will not be visible in the selection inspector but will be visible in the spreadsheet view.
(0017287)
Alan Scott (manager)
2009-09-01 15:11
Please talk to me before implementing. Alan
(0017812)
Nathan Fabian (developer)
2009-09-28 19:53
I've added this and it works as expected for all the exodus files I've looked at (especially the ones above. There may be a number of caveats to how it works with older files. It should work well for serial files. The only really troubling ones are split exodus files which are not detectable from within ExodusIIReader (but are from withing PExodusIIReader). With a work around to detect split files, the caveats for older versions could probably be specialized.
(0017875)
2009-10-01 14:10
Committing Nathan's fixes for BUG 0008422 to 3.6 branch
* Added implicit index arrays as requested in 8422. It is off by default
as there are currently a number of caveats to what numbers will show up
there.
* XML changes to load implicit exodus arrays.
* Added the implicit variables to the exodus variable box, off by default.
/cvsroot/ParaView3/ParaView3/Qt/Components/pqExodusIIPanel.cxx,v <-- Qt/Components/pqExodusIIPanel.cxx
new revision: 1.19.6.3; previous revision: 1.19.6.2
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/readers.xml,v <-- Servers/ServerManager/Resources/readers.xml
new revision: 1.152.2.7; previous revision: 1.152.2.6
/cvsroot/ParaView3/ParaView3/VTK/Hybrid/vtkExodusIIReader.cxx,v <-- VTK/Hybrid/vtkExodusIIReader.cxx
new revision: 1.76.2.3; previous revision: 1.76.2.2
/cvsroot/ParaView3/ParaView3/VTK/Hybrid/vtkExodusIIReader.h,v <-- VTK/Hybrid/vtkExodusIIReader.h
new revision: 1.27.2.2; previous revision: 1.27.2.1
/cvsroot/ParaView3/ParaView3/VTK/Hybrid/vtkExodusIIReaderPrivate.h,v <-- VTK/Hybrid/vtkExodusIIReaderPrivate.h
new revision: 1.6.2.1; previous revision: 1.6
/cvsroot/ParaView3/ParaView3/VTK/Hybrid/vtkExodusModel.cxx,v <-- VTK/Hybrid/vtkExodusModel.cxx
new revision: 1.8.10.1; previous revision: 1.8
/cvsroot/ParaView3/ParaView3/VTK/Hybrid/vtkExodusReader.cxx,v <-- VTK/Hybrid/vtkExodusReader.cxx
new revision: 1.56.10.1; previous revision: 1.56
/cvsroot/ParaView3/ParaView3/VTK/Hybrid/vtkPExodusIIReader.cxx,v <-- VTK/Hybrid/vtkPExodusIIReader.cxx
new revision: 1.27.2.1; previous revision: 1.27
(0017914)
2009-10-02 15:19
Tested with can.exo, client/numerous servers, Linux.
- Issue History
2009-01-22 18:27 Alan Scott New Issue
2009-02-17 16:42 Utkarsh Ayachit Status backlog => tabled
2009-02-17 16:42 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2009-05-13 13:46 Utkarsh Ayachit Target Version => 3.6
2009-08-24 13:18 Ken Moreland Category => Bug
2009-08-24 13:18 Ken Moreland Summary Need exodus node index in selection view => Need implicit exodus node index in selection view
2009-08-24 13:20 Ken Moreland Note Added: 0017185
2009-08-24 16:18 Alan Scott Target Version 3.6 => 3.6.2
2009-09-01 15:11 Alan Scott Note Added: 0017287
2009-09-28 19:53 Nathan Fabian Note Added: 0017812
2009-10-01 14:10 Utkarsh Ayachit Note Added: 0017875
2009-10-01 14:10 Utkarsh Ayachit Status tabled => @80@
2009-10-01 14:10 Utkarsh Ayachit Fixed in Version => 3.6.2
2009-10-01 14:10 Utkarsh Ayachit Resolution open => fixed
2009-10-02 15:11 Alan Scott Relationship added has duplicate 0009341
2009-10-02 15:17 Alan Scott Relationship added related to 0009649
2009-10-02 15:19 Alan Scott Note Added: 0017914
2009-10-02 15:19 Alan Scott Status @80@ => closed
2011-01-13 17:00 Source_changeset_attached => VTK master a2bd8391
2011-01-13 17:00 Source_changeset_attached => VTK master 020ef709
Powered by Mantis Bugtracker
