0008281 | ParaView | Bug | public | 2008-12-10 21:47 | 2010-02-22 20:05 | ||||
Priority | immediate | Severity | feature | Reproducibility | always | ||||
Target Version | 3.8 | Fixed in Version | 3.8 | ||||||
Summary | 0008281: Ability to toggle blocks off by selecting them in one step | ||||||||
Description | I have a user that would like to click on a block, and turn it off. At present, this has to be done as follows: Select block/ Look in Selection Inspector/Find block number/ go to Object inspector/ find block number/ turn it off/ accept. What is wanted is a button such as 'd' that will delete blocks, or a way to automatically hide selected blocks setting in the Selection Inspector, then the user would select the block which would then be hidden. Whatever solution we find, it should include no more than about 2 keystrokes/mouse strokes, etc. | ||||||||
Relationships | ||||||
(0019460) Utkarsh Ayachit (administrator) 2010-02-05 12:27 |
The pqExodusIIPanel now has two buttons that enable the user to quickly check/uncheck the selected blocks. The user creates a block selection the normal way (using the 'B' or the selection toolbar) and then he can use these buttons to update the checked blocks. Note that for this to work, the user has to select the data from the exodus reader itself. /cvsroot/ParaView3/ParaView3/Qt/Components/pqExodusIIPanel.cxx,v <-- Qt/Components/pqExodusIIPanel.cxx new revision: 1.25; previous revision: 1.24 /cvsroot/ParaView3/ParaView3/Qt/Components/pqExodusIIPanel.h,v <-- Qt/Components/pqExodusIIPanel.h new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSILModel.cxx,v <-- Qt/Components/pqSILModel.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSILModel.h,v <-- Qt/Components/pqSILModel.h new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqExodusIIPanel.ui,v <-- Qt/Components/Resources/UI/pqExodusIIPanel.ui new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVCompositeDataInformationIterator.cxx,v <-- Servers/Common/vtkPVCompositeDataInformationIterator.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVCompositeDataInformationIterator.h,v <-- Servers/Common/vtkPVCompositeDataInformationIterator.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSILInformationHelper.cxx,v <-- Servers/ServerManager/vtkSMSILInformationHelper.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSILModel.cxx,v <-- Servers/ServerManager/vtkSMSILModel.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSILModel.h,v <-- Servers/ServerManager/vtkSMSILModel.h new revision: 1.4; previous revision: 1.3 |
(0019585) Alan Scott (manager) 2010-02-22 20:05 |
Tested client/remote server. Linux, trunk. |
2008-12-10 21:47 | Alan Scott | New Issue | |
2009-02-17 15:36 | Utkarsh Ayachit | Category | 3.6 => Pending |
2009-02-20 14:08 | Ken Moreland | Category | Pending => 3.8 |
2009-05-13 13:40 | Utkarsh Ayachit | Target Version | => 3.8 |
2010-01-19 14:19 | Alan Scott | Relationship added | has duplicate 0008564 |
2010-02-01 14:29 | Utkarsh Ayachit | Priority | normal => immediate |
2010-02-01 14:30 | Utkarsh Ayachit | Category | => Bug |
2010-02-05 12:27 | Utkarsh Ayachit | Note Added: 0019460 | |
2010-02-05 12:27 | Utkarsh Ayachit | Status | backlog => @80@ |
2010-02-05 12:27 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
2010-02-05 12:27 | Utkarsh Ayachit | Resolution | open => fixed |
2010-02-05 12:27 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-02-22 20:05 | Alan Scott | Note Added: 0019585 | |
2010-02-22 20:05 | Alan Scott | Status | @80@ => closed |
