0008109ParaView(No Category)public2008-11-17 16:442009-05-13 13:59
ReporterAlan Scott
Assigned ToUtkarsh Ayachit
PriorityhighSeveritymajorReproducibilityalways
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target Version3.4Fixed in Version3.4
Summary0008109: Anotate time goes away
DescriptionThis one is medium-high, minor-major.
Trunk, XP, local server.
Open can.exo.
Sources/Annotate time.
Turn visibility off, turn visibility on of the annotate time.
You cannot get annotate time to ever turn on again. You must delete the filter and recreated it.
TagsNo tags attached.
Project
Topic Name
Type
-  Notes
(0014131)
2008-11-18 09:37
The problem was that the Widget hides the representation
with it's Disabled. Now using "ProcessEvents" to toggle interactivity and using
"Visibility" to affect both widget enabled state as well as representation
visibility.
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMNewWidgetRepresentationProxy.cxx,v <-- Servers/ServerManager/vtkSMNewWidgetRepresentationProxy.cxx
new revision: 1.12; previous revision: 1.11
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMTextSourceRepresentationProxy.cxx,v <-- Servers/ServerManager/vtkSMTextSourceRepresentationProxy.cxx
new revision: 1.9; previous revision: 1.8
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMTextSourceRepresentationProxy.h,v <-- Servers/ServerManager/vtkSMTextSourceRepresentationProxy.h
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- Servers/ServerManager/Resources/rendering.xml
new revision: 1.320; previous revision: 1.319
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/utilities.xml,v <-- Servers/ServerManager/Resources/utilities.xml
new revision: 1.156; previous revision: 1.155
/cvsroot/ParaView3/ParaView3/Qt/Components/pqTextDisplayPropertiesWidget.cxx,v <-- Qt/Components/pqTextDisplayPropertiesWidget.cxx
new revision: 1.11; previous revision: 1.10
(0014139)
Alan Scott (manager)
2008-11-19 17:04
Quick!
Tested client/server.
- Issue History
2008-11-17 16:44 Alan Scott New Issue
2008-11-18 09:37 Utkarsh Ayachit Note Added: 0014131
2008-11-18 09:37 Utkarsh Ayachit Status backlog => @80@
2008-11-18 09:37 Utkarsh Ayachit Resolution open => fixed
2008-11-18 09:37 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2008-11-19 17:04 Alan Scott Note Added: 0014139
2008-11-19 17:04 Alan Scott Status @80@ => closed
2009-05-13 13:58 Utkarsh Ayachit Target Version => 3.4
2009-05-13 13:59 Utkarsh Ayachit Fixed in Version => 3.4
Powered by Mantis Bugtracker
