0007942 | ParaView | (No Category) | public | 2008-11-04 19:52 | 2009-05-13 13:59 | ||||
Summary | 0007942: --data command doesn't work with XP client | ||||||||
Description | When using a client/server connection from XP to Linux, the --data command doesn't work. It should. Using ParaView 3.4.0. This is reported as working on Linux to Linux. This bug must be fixed for ParaView 3.6.0. It is holding up DART from moving from 3.2.1. | ||||||||
(0014574) Utkarsh Ayachit (administrator) 2009-01-15 15:49 |
QFileInfo() was used to split up paths. However if on a windows box and setting up a unix file path (since the server is unix server) then QFileInfo would mess the path up by adding C:/ etc. to it. Fixed that by using SystemTools for determining the path/dir. |
(0014636) Alan Scott (manager) 2009-01-19 21:02 |
Tested local XP client. |
(0014637) Alan Scott (manager) 2009-01-19 21:06 |
Also tested client/server. Works like a champ. |
2008-11-04 19:52 | Alan Scott | New Issue | |
2009-01-12 20:11 | Alan Scott | Priority | normal => high |
2009-01-12 20:11 | Alan Scott | Description Updated | |
2009-01-15 14:37 | Utkarsh Ayachit | Status | backlog => tabled |
2009-01-15 14:37 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-01-15 15:49 | Utkarsh Ayachit | Note Added: 0014574 | |
2009-01-15 15:49 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-01-15 15:49 | Utkarsh Ayachit | Resolution | open => fixed |
2009-01-19 21:02 | Alan Scott | Note Added: 0014636 | |
2009-01-19 21:02 | Alan Scott | Status | @80@ => closed |
2009-01-19 21:06 | Alan Scott | Note Added: 0014637 | |
