0007761 | VTK | (No Category) | public | 2008-10-01 13:54 | 2016-08-12 09:55 | ||||
Reporter | Anka Kochanowska | ||||||||
Summary | 0007761: vtkProperty in 5.2 changed behavior | ||||||||
Description | I tested the following code in vtk 5.0 and 5.2. In 5.0 only tip points of the axes are visible, in 5.2 the lines are visible. vtkAxes * axesSource = vtkAxes::New(); axesSource->SetScaleFactor( 150 ); axesSource->SymmetricOn(); axesSource->ComputeNormalsOff(); vtkPolyDataMapper *axesMapper = vtkPolyDataMapper::New(); axesMapper->SetInput(axesSource->GetOutput()); axesMapper->SetScalarVisibility( 1 ); vtkActor *axesActor = vtkActor::New(); axesActor->SetMapper( axesMapper ); vtkProperty *property = vtkProperty::New(); property->SetRepresentation( VTK_POINTS ); axesActor->SetProperty( property ); | ||||||||
(0037025) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2008-10-01 13:54 | Anka Kochanowska | New Issue | |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037025 | |
2016-08-12 09:55 | Kitware Robot | Status | expired => closed |
2016-08-12 09:55 | Kitware Robot | Resolution | open => moved |
2016-08-12 09:55 | Kitware Robot | Assigned To | => Kitware Robot |
