0007730ParaView(No Category)public2008-09-24 16:012009-05-13 13:59
ReporterAlan Scott
Assigned ToUtkarsh Ayachit
PriorityhighSeveritymajorReproducibilityalways
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target Version3.4Fixed in Version3.4
Summary0007730: Edit Color Map icon is bad
DescriptionThis is replicated on ParaView trunk, assuming it is in 3.4. It must be fixed for the 3.4 release, if possible.
Local server. XP.
* Open disk_out_ref.exo. All variables on. Apply.
* Rotate the can so you can see inside.
* Edit_Color_Map icon on the main toolbar.
* Change color to dark red (top row, second from left). OK.
>>> Error - nothing changes.
* Next, change Solid Color to Temp.
>>> Error - All of the blue has gone black. Should a change to the solid color really effect the lights? I checked lights, they look OK. I checked materials (through the Edit Color Map on the Display tab), they seem OK.
* Note - I am using one headlight. Changing headlight color back to white didn't fix it.
TagsNo tags attached.
Project
Topic Name
Type
-  Notes
(0013582)
2008-09-25 13:46
pqColorScaleToolbar wasn't push property value changes hence the
effect was delayed. vtkOpenGLScalarsToColorsPainter was erroneously enabling
color material when texture was used for scalar coloring. That resulted in
interference between the material properties and scalar color.
/cvsroot/ParaView3/ParaView3/VTK/Rendering/vtkOpenGLScalarsToColorsPainter.cxx,v <-- VTK/Rendering/vtkOpenGLScalarsToColorsPainter.cxx
new revision: 1.8; previous revision: 1.7
/cvsroot/ParaView3/ParaView3/Qt/Components/pqColorScaleToolbar.cxx,v <-- Qt/Components/pqColorScaleToolbar.cxx
new revision: 1.5; previous revision: 1.4
(0013611)
Alan Scott (manager)
2008-09-26 20:26
Very nice. Tested client/server.
- Issue History
2008-09-24 16:01 Alan Scott New Issue
2008-09-24 16:01 Alan Scott Status backlog => tabled
2008-09-24 16:01 Alan Scott Assigned To => Utkarsh Ayachit
2008-09-25 13:46 Utkarsh Ayachit Status tabled => @80@
2008-09-25 13:46 Utkarsh Ayachit Resolution open => fixed
2008-09-25 13:46 Utkarsh Ayachit Note Added: 0013582
2008-09-26 20:26 Alan Scott Status @80@ => closed
2008-09-26 20:26 Alan Scott Note Added: 0013611
2009-05-13 13:58 Utkarsh Ayachit Target Version => 3.4
2009-05-13 13:59 Utkarsh Ayachit Fixed in Version => 3.4
Powered by Mantis Bugtracker
