0007510 | ParaView | (No Category) | public | 2008-08-20 08:56 | 2009-05-13 13:59 | ||||
Priority | normal | Severity | major | Reproducibility | have not tried | ||||
Summary | 0007510: 2D view does not work with images w/o scalar array | ||||||||
Description | If you have image data that does not have any of its point fields identified as the active scalars, then the 2D view does not work. To replicate, load the attached data file, which has a point data array named "Iterations" that is not defined as the scalars. When it comes up in the 2D view, you will get the following errors: Warning: In C:\kmorel\src\ParaView3\Servers\Filters\vtkTexturePainter.cxx, line 173 vtkTexturePainter (0BD72488): Failed to locate selected scalars. Will use image scalars by default. ERROR: In C:\kmorel\src\ParaView3\VTK\Rendering\vtkOpenGLTexture.cxx, line 210 vtkOpenGLTexture (0BD728C8): No scalar values found for texture input! The latter error is repeated on every frame update. | ||||||||
Attached Files | ImageNoScalars.vtk [^] (252,201 bytes) 2008-08-20 08:56 | ||||||||
(0013126) Utkarsh Ayachit (administrator) 2008-08-21 10:33 |
For representation types that cannot use solid coloring, color by some array if no active scalars are found. /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineRepresentation.cxx,v <-- Qt/Core/pqPipelineRepresentation.cxx new revision: 1.32; previous revision: 1.31 |
(0013175) Alan Scott (manager) 2008-08-25 12:35 |
Tested local client. |
2008-08-20 08:56 | Ken Moreland | New Issue | |
2008-08-20 08:56 | Ken Moreland | File Added: ImageNoScalars.vtk | |
2008-08-20 08:56 | Ken Moreland | Status | backlog => tabled |
2008-08-20 08:56 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
2008-08-21 10:33 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-08-21 10:33 | Utkarsh Ayachit | Resolution | open => fixed |
2008-08-21 10:33 | Utkarsh Ayachit | Note Added: 0013126 | |
2008-08-25 12:35 | Alan Scott | Status | @80@ => closed |
2008-08-25 12:35 | Alan Scott | Note Added: 0013175 | |
