0007444VTK(No Category)public2008-08-02 02:442013-04-05 19:59
ReporterDominik Szczerba
Assigned ToDavid Partyka
PrioritynormalSeveritycrashReproducibilityalways
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Summary0007444: vtkHdf5 library crashes with chunked datasets
Descriptionopening a chunked dataset (through a plugin) using PV3 CVS crashes the application with a traceback leading to vtkHdf5 lib. Just compiling PV with a system hdf5 (here 1.6.7) solves the problem, so obviously the version 1.6.5 included in the PV CVS tree has a problem with PV.
TagsNo tags attached.
Project
Type
-  Notes
(0012947)
Sean McBride (developer)
2008-08-06 10:47
How different are 1.6.5 and 1.6.7? Would it be hard to update VTK's version? For example, does VTK use plain 1.6.5 or is VTK's version heavily modified from 1.6.5?
(0023626)
David Partyka (developer)
2010-11-30 22:57
ParaView now includes hdf5-1.8.5. Please report a bug under the ParaView project if you're still experiencing any issues.
- Issue History
2008-08-02 02:44 Dominik Szczerba New Issue
2008-08-06 10:47 Sean McBride Note Added: 0012947
2010-11-30 22:57 David Partyka Note Added: 0023626
2010-11-30 22:57 David Partyka Status backlog => @80@
2010-11-30 22:57 David Partyka Resolution open => fixed
2010-11-30 22:57 David Partyka Assigned To => David Partyka
2013-04-05 19:59 Berk Geveci Status customer review => closed
Powered by Mantis Bugtracker
