0007301 | ParaView | (No Category) | public | 2008-07-07 19:00 | 2011-01-13 17:00 | ||||
Priority | high | Severity | crash | Reproducibility | always | ||||
Summary | 0007301: Screenshots of clip box are crashing ParaView | ||||||||
Description | This only seems to happen when I am doing a clip to a box. Strange! Client/multiple server Wavelet, apply. Clip/ Box. Change X to 0.9. Apply. File/ Save Screenshot/ any file type (.jpg crashes). Here is the error output: ERROR: In C:\alan\paraviewNightlyTrunk\src\ParaView3\VTK\Rendering\vtkOpenGLRenderer.cxx, line 852 vtkOpenGLRenderer (09EA0D38): shader source compile error ERROR: In C:\alan\paraviewNightlyTrunk\src\ParaView3\VTK\Rendering\vtkOpenGLRenderer.cxx, line 864 vtkOpenGLRenderer (09EA0D38): no log ERROR: In C:\alan\paraviewNightlyTrunk\src\ParaView3\VTK\Rendering\vtkOpenGLRenderer.cxx, line 910 vtkOpenGLRenderer (09EA0D38): program link error ERROR: In C:\alan\paraviewNightlyTrunk\src\ParaView3\VTK\Rendering\vtkOpenGLRenderer.cxx, line 924 vtkOpenGLRenderer (09EA0D38): no log: Qt has caught an exception thrown from an event handler. Throwing exceptions from an event handler is not supported in Qt. You must reimplement QApplication::notify() and catch all exceptions there. | ||||||||
(0012666) Utkarsh Ayachit (administrator) 2008-07-09 08:04 |
Actually...not that strange. I am guessing this has something to do with depth peeling being used with offscreen context (which is created for saving images). Depth peeling is being used since the box widget reports that it has translucent panels. Easy fix would be to disable translucency. |
(0012822) Utkarsh Ayachit (administrator) 2008-07-25 09:34 |
When the faces are not selected, their opacity is 0. In reality when opacity is 0, it should not affect the consideration if depth peeling is used since it doesn't really matter. However, vtkActor::GetIsOpaque() return false when opacity is 0, and we end up using depth peeling. The more complete fix would need some change to the actor API. For now, simply not considering the face into translucency check unless it is selected does the trick. /cvsroot/ParaView3/ParaView3/VTK/Widgets/vtkBoxRepresentation.cxx,v <-- VTK/Widgets/vtkBoxRepresentation.cxx new revision: 1.7; previous revision: 1.6 |
(0012844) Alan Scott (manager) 2008-07-28 19:16 |
Tested client/server |
2008-07-07 19:00 | Alan Scott | New Issue | |
2008-07-09 08:01 | Utkarsh Ayachit | Status | backlog => tabled |
2008-07-09 08:01 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2008-07-09 08:03 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => |
2008-07-09 08:04 | Utkarsh Ayachit | Note Added: 0012666 | |
2008-07-09 10:51 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2008-07-25 09:34 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-07-25 09:34 | Utkarsh Ayachit | Resolution | open => fixed |
2008-07-25 09:34 | Utkarsh Ayachit | Note Added: 0012822 | |
2008-07-28 19:16 | Alan Scott | Status | @80@ => closed |
2008-07-28 19:16 | Alan Scott | Note Added: 0012844 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
