0007237 | ParaView | (No Category) | public | 2008-06-25 05:18 | 2009-05-13 13:47 | ||||
Reporter | Stephane P | ||||||||
Summary | 0007237: bug with IceT when maximizing a view | ||||||||
Description | in the attached state file, there are 3 views. When the bottom-right one is maximized to fill up the whole view space, it is maximized on the client, but not on the image wall. to test it, you can launch the server with pvserver -tdx=1 | ||||||||
Project | ParaViS | ||||||||
Attached Files | test.pvsm [^] (142,001 bytes) 2008-06-25 05:18 | ||||||||
(0013722) Utkarsh Ayachit (administrator) 2008-10-03 10:25 |
When in client-server mode (without tiles), we want the client-server render sync manager to use the client-render window's size to determine the size for the server-renderwindow. The actual placement of the frame on the client doesn't really matter since the server renders one frame at a time. However when on tile-display, both the client GUI size and relative frame position needs to be conveyed to the server correctly. This wasn't the case before. Fixed it. Also after maximize or minimize explicitly call pqViewManager::updateViewPositions() so that the new frame positions are pushed. /cvsroot/ParaView3/ParaView3/Qt/Components/pqMultiView.h,v <-- Qt/Components/pqMultiView.h new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/Qt/Components/pqViewManager.cxx,v <-- Qt/Components/pqViewManager.cxx new revision: 1.65; previous revision: 1.64 /cvsroot/ParaView3/ParaView3/Qt/Components/pqViewManager.h,v <-- Qt/Components/pqViewManager.h new revision: 1.23; previous revision: 1.22 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMIceTDesktopRenderViewProxy.cxx,v <-- Servers/ServerManager/vtkSMIceTDesktopRenderViewProxy.cxx new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMIceTMultiDisplayRenderViewProxy.cxx,v <-- Servers/ServerManager/vtkSMIceTMultiDisplayRenderViewProxy.cxx new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMIceTMultiDisplayRenderViewProxy.h,v <-- Servers/ServerManager/vtkSMIceTMultiDisplayRenderViewProxy.h new revision: 1.4; previous revision: 1.3 |
(0013924) Alan Scott (manager) 2008-10-24 19:05 |
Marking closed untested. |
2008-06-25 05:18 | Stephane P | New Issue | |
2008-06-25 05:18 | Stephane P | File Added: test.pvsm | |
2008-06-25 09:58 | Ken Moreland | Category | 3.4 => 3.6 |
2008-10-03 10:25 | Utkarsh Ayachit | Status | backlog => @80@ |
2008-10-03 10:25 | Utkarsh Ayachit | Resolution | open => fixed |
2008-10-03 10:25 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2008-10-03 10:25 | Utkarsh Ayachit | Note Added: 0013722 | |
2008-10-24 19:05 | Alan Scott | Note Added: 0013924 | |
2008-10-24 19:05 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:47 | Utkarsh Ayachit | Target Version | => 3.6 |
2011-06-23 11:44 | Utkarsh Ayachit | Project | => ParaViS |
