0007233 | ParaView | (No Category) | public | 2008-06-23 19:21 | 2009-05-13 13:59 | ||||
Assigned To | |||||||||
Summary | 0007233: Lights messed up with multi-block | ||||||||
Description | Lights seem to be messed up with multi-block. run paraview client/server. Open data as found in file testData.tar.gz, from Burlen, which was the test data for bug number 7145. This directory has mbmpTest_**.vtp in it. Filter/ Extract Block, select block 0, Apply. Color by Pressure. Toggle color legend visibility Notice the color is darkish. Turn on the eyeball for the mbmpTest.vtm. Notice that the colors become bright. I am setting this to high priority because it mis represents data, and because multiblock is our main focus of this release. | ||||||||
(0012508) Alan Scott (manager) 2008-06-24 16:21 |
This was a mistake in my .ini file. No idea why an .ini file caused it, but by removing the .ini file, everything works fine. Tested as per directions, client/server. |
2008-06-23 19:21 | Alan Scott | New Issue | |
2008-06-24 16:21 | Alan Scott | Status | backlog => closed |
2008-06-24 16:21 | Alan Scott | Note Added: 0012508 | |
2008-06-24 16:21 | Alan Scott | Resolution | open => fixed |
