0007144 | ParaView | (No Category) | public | 2008-06-03 09:21 | 2009-05-13 13:59 | ||||
Summary | 0007144: For Empty multi-blocks, vtkPVDatainformation should say it's of type vtkDataObject|vtkDataSet | ||||||||
Description | To see the issue try applying ExtractBlock with no blocks selected. | ||||||||
(0012331) Utkarsh Ayachit (administrator) 2008-06-12 14:00 |
For composite datasets with no leaves, the data type is set to vtkDataSet so that ParaView creates the default representation. /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVDataInformation.cxx,v <-- Servers/Common/vtkPVDataInformation.cxx new revision: 1.53; previous revision: 1.52 The problem was that when Extract Block was applied the first time without any block selected, no representation would be created. Consequently, changing the block selection later would have no effect. Fixed that. |
(0012386) Alan Scott (manager) 2008-06-17 16:33 |
Tested, as much as I could figure out to test. |
2008-06-03 09:21 | Utkarsh Ayachit | New Issue | |
2008-06-03 11:45 | Utkarsh Ayachit | Status | backlog => tabled |
2008-06-03 11:45 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2008-06-12 14:00 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-06-12 14:00 | Utkarsh Ayachit | Resolution | open => fixed |
2008-06-12 14:00 | Utkarsh Ayachit | Note Added: 0012331 | |
2008-06-17 16:33 | Alan Scott | Status | @80@ => closed |
2008-06-17 16:33 | Alan Scott | Note Added: 0012386 | |
