0007126 | ParaView | (No Category) | public | 2008-05-30 10:31 | 2009-05-13 13:59 | ||||
Summary | 0007126: Disable global id selection when global ids are not available. | ||||||||
Description | * Create wavelet. * convert to surface repr. * select on surface. * Go to selection inspector and convert to global ids. Results are wrong since wavelet has no global ids. Disable global id selection when global ids are not available. | ||||||||
Relationships | ||||||
(0012507) Utkarsh Ayachit (administrator) 2008-06-24 16:13 |
Selection type change to Global IDs is not available unless the data has global ids. /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqSelectionInspectorPanel.ui,v <-- Qt/Components/Resources/UI/pqSelectionInspectorPanel.ui new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInspectorPanel.h,v <-- Qt/Components/pqSelectionInspectorPanel.h new revision: 1.17; previous revision: 1.16 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInspectorPanel.cxx,v <-- Qt/Components/pqSelectionInspectorPanel.cxx new revision: 1.29; previous revision: 1.28 |
(0012587) Alan Scott (manager) 2008-06-30 19:07 |
Tested client/server |
2008-05-30 10:31 | Utkarsh Ayachit | New Issue | |
2008-05-30 10:31 | Utkarsh Ayachit | Relationship added | related to 0006783 |
2008-05-30 16:37 | Ken Moreland | Status | backlog => tabled |
2008-05-30 16:37 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
2008-06-24 16:13 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-06-24 16:13 | Utkarsh Ayachit | Resolution | open => fixed |
2008-06-24 16:13 | Utkarsh Ayachit | Note Added: 0012507 | |
2008-06-30 19:07 | Alan Scott | Status | @80@ => closed |
2008-06-30 19:07 | Alan Scott | Note Added: 0012587 | |
