0007120 | ParaView | (No Category) | public | 2008-05-29 10:00 | 2009-05-13 13:59 | ||||
Priority | normal | Severity | crash | Reproducibility | have not tried | ||||
Summary | 0007120: Crash during reselection in spreadsheet | ||||||||
Description | Under some circumstances when you select in the spreadsheet view, ParaView crashes. Here is how to replicate the problem. 1. Load/create data. Sphere source is fine. 2. Create a spreadsheet view. The sphere should automatically become visible in the spreadsheet. 3. Select some rows in the spreadsheet. 4. With the spreadsheet view still active, create an extract selection filter, copy the active selection, and apply. The spreadsheet view will now show the active selection. 5. Click on any row in the spreadsheet. Crash. | ||||||||
(0012161) Utkarsh Ayachit (administrator) 2008-05-30 10:28 |
vtkIndexBasedBlockFilter was not adding original indicies when the input was from an extract selection filter. This was needed to now show duplicate point/cell ids in "selection only" mode. However, as result when one applied the extract selection filter, the vtkOriginalIndicies array was not added. Consequently, spreadsheet based selections could not be made on the output of the extract selection filter. Fixed that. Now in selection only mode, the vtkSMSpreadSheetRepresentationProxy explicitly tells vtkIndexBasedBlockFilter to not add vtkOriginalIndicies array. --------------------------- commit id: YB6Us5y4LCSsQZ4t --------------------------- /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkIndexBasedBlockFilter.cxx,v <-- Servers/Filters/vtkIndexBasedBlockFilter.cxx new revision: 1.20; previous revision: 1.19 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkIndexBasedBlockFilter.h,v <-- Servers/Filters/vtkIndexBasedBlockFilter.h new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSpreadSheetRepresentationProxy.cxx,v <-- Servers/ServerManager/vtkSMSpreadSheetRepresentationProxy.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- Servers/ServerManager/Resources/rendering.xml new revision: 1.296; previous revision: 1.295 |
(0012197) Alan Scott (manager) 2008-06-02 19:17 |
Fixed. Tested client/server. |
2008-05-29 10:00 | Ken Moreland | New Issue | |
2008-05-29 10:01 | Ken Moreland | Status | backlog => tabled |
2008-05-29 10:01 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
2008-05-30 10:28 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-05-30 10:28 | Utkarsh Ayachit | Resolution | open => fixed |
2008-05-30 10:28 | Utkarsh Ayachit | Note Added: 0012161 | |
2008-06-02 19:17 | Alan Scott | Status | @80@ => closed |
2008-06-02 19:17 | Alan Scott | Note Added: 0012197 | |
