0007057 | VTK | (No Category) | public | 2008-05-20 04:47 | 2016-08-12 09:54 | ||||
Reporter | Laurent PAUL | ||||||||
Summary | 0007057: vtkImplicitPlaneWidget does not change state in RightButtonDown if scale is disabled | ||||||||
Description | When left clicking in the widget (normal or plane), plane state switch to Rotationg or Pushing. If right clicking outside of the widget, plane does not turn its state to Outside because of the "if" test on ScaleEnabled member. If Scale is off, widget remains in its initial state eg. Start and camera is zooming in and out... | ||||||||
Additional Information | I added an "else" to the "if" test which turns state of the widget to Outside. If we are not interested in scaling the widget, so it has to act as if we were always right clicking outside the widget. | ||||||||
(0015124) Fabio Menegazzo (reporter) 2009-02-18 07:24 |
Are you using a custom interactor style? Because I had a similar problem but I solved it with VTK 5.2.1 using the vtkImplicitPlaneWidget2 instead of vtkImplicitPlaneWidget. |
(0015125) Laurent PAUL (reporter) 2009-02-18 07:36 |
No, I use the vtkInteractorStyleTrackballCamera. I work with FLTK and events are propagated to VTK using a vtkFlRenderWindowInteractor class that interprets all events into vtkCommands. I no longer have this bug since I corrected it using the tip provided with the report. Laurent. |
(0036974) Kitware Robot (administrator) 2016-08-12 09:54 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2008-05-20 04:47 | Laurent PAUL | New Issue | |
2009-02-18 07:24 | Fabio Menegazzo | Note Added: 0015124 | |
2009-02-18 07:36 | Laurent PAUL | Note Added: 0015125 | |
2016-08-12 09:54 | Kitware Robot | Note Added: 0036974 | |
2016-08-12 09:54 | Kitware Robot | Status | expired => closed |
2016-08-12 09:54 | Kitware Robot | Resolution | open => moved |
2016-08-12 09:54 | Kitware Robot | Assigned To | => Kitware Robot |
