0007035 | ParaView | (No Category) | public | 2008-05-15 17:44 | 2009-05-13 13:59 | ||||
Summary | 0007035: Filters don't work on the 2d window | ||||||||
Description | Filters don't seem to work on the 2d window. * ParaView, XP, trunk. * Bring up a mandlebrot source. * Normally, you would close the 3d window, but don't for this example. * Threshold, change lower threshold to 4, apply. You see nothing. * Select the 3d window, turn eyeball on. At least you now see something. Colors are wrong. * Rescale to Data Range. NOW you finally see something. This should have occurred in the 2d window. Same problem for clipping, and I would assume, others. | ||||||||
(0012023) Ken Moreland (manager) 2008-05-20 09:33 |
The result of the Threshold cannot be shown in the 2D view because it is an unstructured grid. The 2D view only works with 2D image data. However, ParaView should create a view in which it can be seen using the standard incompatible view type rules. |
(0012165) Utkarsh Ayachit (administrator) 2008-05-30 13:47 |
If I remember correctly, we never create a 3D view unless the active view is blank. eg. Apply histogram -- with bar chart view selected, create a sphere source -- we don't create a new 3D view for the sphere. Don't remember why we decided to do that. Should that behaviour change? Should we always create a new 3D view if the new source cannot be shown in the current view? |
(0012172) Ken Moreland (manager) 2008-05-30 16:58 |
I'm not sure if that was a conscious decision or just how things came out. I went back and scanned the original design document (http://www.paraview.org/ParaView3/index.php/New_Object_View [^]) and did not see anything specific to 3D views. Rather, the rules for new views are specifically generic. I see no reason why 3D views should deviate from them. |
(0012175) Utkarsh Ayachit (administrator) 2008-05-31 11:02 |
If the active cannot show the current data and there's no preferred view type defined, then we create a new 3D view to show it. /cvsroot/ParaView3/ParaView3/Qt/Core/pqDisplayPolicy.cxx,v <-- Qt/Core/pqDisplayPolicy.cxx new revision: 1.37; previous revision: 1.36 /cvsroot/ParaView3/ParaView3/Qt/Core/pqDisplayPolicy.h,v <-- Qt/Core/pqDisplayPolicy.h new revision: 1.10; previous revision: 1.9 |
(0012187) Alan Scott (manager) 2008-06-02 16:30 |
Acceptable solution. Tested client/server. |
2008-05-15 17:44 | Alan Scott | New Issue | |
2008-05-20 09:31 | Ken Moreland | Status | backlog => tabled |
2008-05-20 09:31 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
2008-05-20 09:33 | Ken Moreland | Note Added: 0012023 | |
2008-05-30 13:47 | Utkarsh Ayachit | Note Added: 0012165 | |
2008-05-30 16:58 | Ken Moreland | Note Added: 0012172 | |
2008-05-31 11:02 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-05-31 11:02 | Utkarsh Ayachit | Resolution | open => fixed |
2008-05-31 11:02 | Utkarsh Ayachit | Note Added: 0012175 | |
2008-06-02 16:30 | Alan Scott | Status | @80@ => closed |
2008-06-02 16:30 | Alan Scott | Note Added: 0012187 | |
