0007014 | ParaView | (No Category) | public | 2008-05-14 04:20 | 2009-05-13 13:59 | ||||
Reporter | Mattijs | ||||||||
Summary | 0007014: rescale to data range does not work on thresholded data | ||||||||
Description | Load in file. Threshold on variable. Now colour thresholded data with same variable. Press 'Rescale to Data Range'. Produces colour bar 0..1 instead of proper range. (the Information tab does show the correct range). This is with the 3.3-cvs version from around 1/5/8 | ||||||||
(0011895) Ken Moreland (manager) 2008-05-14 10:10 |
Works for me for CVS build last night (5/13/08). I used the Wavelet source, showed the surface, colored by RTData, thresholded on RTData, rescaled based on the output of the threshold. The threshold range was fine. |
(0011934) Alan Scott (manager) 2008-05-14 19:28 |
Tested local server, using disk_out_ref.exo and Temp. Looks correct to me. |
(0011959) Mattijs (reporter) 2008-05-16 08:57 |
Can't repeat it myself either. Must have made mistake. Sorry. |
2008-05-14 04:20 | Mattijs | New Issue | |
2008-05-14 10:10 | Ken Moreland | Status | backlog => @80@ |
2008-05-14 10:10 | Ken Moreland | Resolution | open => unable to reproduce |
2008-05-14 10:10 | Ken Moreland | Assigned To | => Ken Moreland |
2008-05-14 10:10 | Ken Moreland | Note Added: 0011895 | |
2008-05-14 19:28 | Alan Scott | Status | @80@ => closed |
2008-05-14 19:28 | Alan Scott | Note Added: 0011934 | |
2008-05-16 08:57 | Mattijs | Status | closed => @20@ |
2008-05-16 08:57 | Mattijs | Resolution | unable to reproduce => reopened |
2008-05-16 08:57 | Mattijs | Note Added: 0011959 | |
2008-05-16 09:22 | Ken Moreland | Status | @20@ => closed |
2008-05-16 09:22 | Ken Moreland | Resolution | reopened => fixed |
