0006956 | ParaView | (No Category) | public | 2008-05-05 12:19 | 2011-01-13 17:00 | ||||
Summary | 0006956: Temporal statistics filter output reports wrong ranges | ||||||||
Description | When you run the temporal statistics filter on some data, the resulting _average, _minimum, and _maximum arrays all have the same range reported in the information panel. This also leads to the scalar bar being given the wrong range. To replicate, load in can.ex2 with the EQPS variable loaded. Then run that through the temporal statistics filter. Look at the resulting information panel and you will see that all the EQPS_* variables (except the stddev one) have the range of [0, 1.67562], which is clearly wrong. | ||||||||
Relationships | |||||||
(0011697) Ken Moreland (manager) 2008-05-05 12:22 |
The problem is that vtkInformation is not properly doing a deep copy (bug 0006955), which is causing all of the arrays to share the range information key even though they are not sharing the data. I have attached a patch to bug 0006955 that fixes the problem for this bug. However, I don't want to be fiddling with such a core class of VTK, so I'll let one of the maintainers of VTK at Kitware review and apply the patch. |
(0013208) Utkarsh Ayachit (administrator) 2008-08-27 12:12 |
A fix for the VTK issue was committed. |
(0013269) Alan Scott (manager) 2008-09-02 21:30 |
Tested client/server. |
2008-05-05 12:19 | Ken Moreland | New Issue | |
2008-05-05 12:20 | Ken Moreland | Relationship added | parent of 0006955 |
2008-05-05 12:22 | Ken Moreland | Note Added: 0011697 | |
2008-05-05 12:22 | Ken Moreland | Status | backlog => tabled |
2008-05-05 12:22 | Ken Moreland | Assigned To | => Berk Geveci |
2008-06-03 11:12 | Utkarsh Ayachit | Assigned To | Berk Geveci => Burlen |
2008-08-07 13:16 | Utkarsh Ayachit | Assigned To | Burlen => Berk Geveci |
2008-08-26 13:49 | Utkarsh Ayachit | Assigned To | Berk Geveci => Utkarsh Ayachit |
2008-08-27 12:12 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-08-27 12:12 | Utkarsh Ayachit | Resolution | open => fixed |
2008-08-27 12:12 | Utkarsh Ayachit | Note Added: 0013208 | |
2008-09-02 21:30 | Alan Scott | Status | @80@ => closed |
2008-09-02 21:30 | Alan Scott | Note Added: 0013269 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
