0006944 | ParaView | (No Category) | public | 2008-05-02 12:01 | 2009-05-13 13:59 | ||||
Summary | 0006944: Color legend numbers aren't consistent length | ||||||||
Description | Color legend numbers are variable length. The following test shows this trivially: * Open can.exo. * Color by cellNormals * Turn on the color legend. One idea would be to '0' pad all numbers to be a consistent length. Another would be to allow the user to be able to change the display as a printf format - as we do with the annotate time source. | ||||||||
Relationships | ||||||
(0011733) Ken Moreland (manager) 2008-05-07 14:34 |
Color legend numbers have always been of inconsistent length. I'm not sure we even want them to be consistent length. If they were, numbers like 1.00, 10.0, and 100. all look about the same. Is there a reason why we want consistent length numbers now? |
(0011734) Ken Moreland (manager) 2008-05-07 14:42 |
Looking through my email, it looks like the real complaint is that you can no longer specify your own format if you want it. I submitted a bug (0006984) to be able to specify your own label format. I will assign myself this bug and declare it done once you can specify your own label format. |
(0011746) Ken Moreland (manager) 2008-05-08 09:50 |
/cvsroot/ParaView3/ParaView3/Qt/Components/pqColorScaleEditor.cxx,v <-- Qt/Components/pqColorScaleEditor.cxx new revision: 1.43; previous revision: 1.42 /cvsroot/ParaView3/ParaView3/Qt/Components/pqColorScaleEditor.h,v <-- Qt/Components/pqColorScaleEditor.h new revision: 1.17; previous revision: 1.16 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqColorScaleDialog.ui,v <-- Qt/Components/Resources/UI/pqColorScaleDialog.ui new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVScalarBarActor.cxx,v <-- Servers/Filters/vtkPVScalarBarActor.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVScalarBarActor.h,v <-- Servers/Filters/vtkPVScalarBarActor.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- Servers/ServerManager/Resources/rendering.xml new revision: 1.283; previous revision: 1.282 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/utilities.xml,v <-- Servers/ServerManager/Resources/utilities.xml new revision: 1.141; previous revision: 1.140 |
(0011842) Alan Scott (manager) 2008-05-12 18:00 |
Wow! tested client/server. |
2008-05-02 12:01 | Alan Scott | New Issue | |
2008-05-07 14:34 | Ken Moreland | Note Added: 0011733 | |
2008-05-07 14:34 | Ken Moreland | Category | 3.4 => Someday |
2008-05-07 14:42 | Ken Moreland | Note Added: 0011734 | |
2008-05-07 14:42 | Ken Moreland | Status | backlog => tabled |
2008-05-07 14:42 | Ken Moreland | Assigned To | => Ken Moreland |
2008-05-07 14:42 | Ken Moreland | Category | Someday => 3.4 |
2008-05-08 09:50 | Ken Moreland | Status | tabled => @80@ |
2008-05-08 09:50 | Ken Moreland | Resolution | open => fixed |
2008-05-08 09:50 | Ken Moreland | Note Added: 0011746 | |
2008-05-08 09:50 | Ken Moreland | Relationship added | related to 0006984 |
2008-05-12 18:00 | Alan Scott | Status | @80@ => closed |
2008-05-12 18:00 | Alan Scott | Note Added: 0011842 | |
