0006940 | ParaView | Bug | public | 2008-05-01 17:42 | 2016-08-12 09:57 | ||||
Reporter | Burlen | ||||||||
Summary | 0006940: vtkSpyPlotReadert Reader does not "correctly" build dataset | ||||||||
Description | MultiBlock data should have AMR box filled with global extents of its associated image data, but spyplot reader instead fills this with an indicator of weather or not ghost cells have been stripped from this block. Given the CTH format, much information needed for post-processing filters is available in the reader but not provided, for example: Level 0 dx Data set Origin Standard block size Index space bounding box(like chombo problem domain) In addition all processes need to know the global structure of the data set, (ie have access to AMR Boxes which contain the global extents of each block.) This type of information is needed for neighbor finding etc... Currently as the items are not provided each instance of the post processing filter then must attempt to deduce and communicate this information amongst its process,leading to complicated code, extra communication and processing overhead. | ||||||||
(0037571) Kitware Robot (administrator) 2016-08-12 09:57 |
2008-05-01 17:42 | Burlen | New Issue | |
2009-02-17 16:07 | Ken Moreland | Status | backlog => tabled |
2009-02-17 16:07 | Ken Moreland | Assigned To | => Burlen |
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
2009-08-25 18:44 | Utkarsh Ayachit | Assigned To | Burlen => |
2009-08-25 18:44 | Utkarsh Ayachit | Category | => Bug |
2009-08-25 18:44 | Utkarsh Ayachit | Target Version | 3.6 => 3.8 |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037571 | |
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
