0006921ParaView(No Category)public2008-04-29 09:022009-05-13 13:47
ReporterUtkarsh Ayachit
Assigned ToUtkarsh Ayachit
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target Version3.6Fixed in Version
Summary0006921: Exodus reader does not assign block names
DescriptionParaView/VTK now supports naming blocks. One can simply put a value for vtkCompositeDataSet::NAME() key in the meta-data associate with a block as the name for the block. Exodus reader does not assign any names to blocks. (Ensight readers can be used as an example how to assign names).
TagsNo tags attached.
Project
Topic Name
Type
 Relationships
  Notes
(0011866)
Ken Moreland (manager)
2008-05-13 12:51
At some point someone needs to do some major updates to the Exodus writer. Part of the plan for that work is to get rid of any special metadata objects and just store metadata in the information objects of the dataset. This bug should be part of that work.
(0013583)
2008-09-25 14:24
Exodus reader assigns names to blocks so that the names used for the block/set selection API are same.
Commit to directory "ParaView3/VTK/Hybrid" lies in external project VTK
/cvsroot/ParaView3/ParaView3/VTK/Hybrid/vtkExodusIIReader.cxx,v <-- VTK/Hybrid/vtkExodusIIReader.cxx
new revision: 1.70; previous revision: 1.69
(0013737)
Alan Scott (manager)
2008-10-06 19:24
Fabulous! Tested on trunk, Local ParaView.
 Issue History
2008-04-29 09:02 Utkarsh Ayachit New Issue
2008-04-29 09:03 Utkarsh Ayachit Description Updated
2008-05-13 12:51 Ken Moreland Note Added: 0011866
2008-05-13 12:51 Ken Moreland Category 3.4 => 3.6
2008-09-25 14:24 Utkarsh Ayachit Status backlog => @80@
2008-09-25 14:24 Utkarsh Ayachit Resolution open => fixed
2008-09-25 14:24 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2008-09-25 14:24 Utkarsh Ayachit Note Added: 0013583
2008-10-06 19:24 Alan Scott Status @80@ => closed
2008-10-06 19:24 Alan Scott Note Added: 0013737
2009-05-13 13:47 Utkarsh Ayachit Target Version Multi-block support => 3.6
