0006915 | ParaView | (No Category) | public | 2008-04-28 12:42 | 2009-05-13 13:59 | ||||
Priority | low | Severity | feature | Reproducibility | always | ||||
Summary | 0006915: Block selection request with <ctrl> | ||||||||
Description | We need the ability to toggle block selections without effecting other blocks. For instance, if I want to select two blocks using the 'b' command, it would be userful to be able to select 'b', then <ctrl> 'b' on another block. Another use for this <ctrl> function would be that if the user ever used "Select cells on", with the <ctrl> key down, it would select all BLOCKS that held cells that were rubber band selected. Maybe a stretch goal would be that if the user used the <alt> key when the "Select cells on" rubber band was used, only those blocks that had all cells selected would be highlighted. Selecting a washer within a nut/bolt group comes to mind. | ||||||||
(0012151) Berk Geveci (administrator) 2008-05-29 13:37 |
This is a stretch goal for 3.4 |
(0012171) Utkarsh Ayachit (administrator) 2008-05-30 16:34 |
Expanding selections using Ctrl is now supported. Only works for ids based selection and block selection. /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderView.cxx,v <-- Qt/Core/pqRenderView.cxx new revision: 1.39; previous revision: 1.38 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderView.h,v <-- Qt/Core/pqRenderView.h new revision: 1.22; previous revision: 1.21 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRubberBandHelper.cxx,v <-- Qt/Core/pqRubberBandHelper.cxx new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSelectionHelper.cxx,v <-- Servers/ServerManager/vtkSMSelectionHelper.cxx new revision: 1.18; previous revision: 1.17 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSelectionHelper.h,v <-- Servers/ServerManager/vtkSMSelectionHelper.h new revision: 1.6; previous revision: 1.5 |
(0012191) Alan Scott (manager) 2008-06-02 18:53 |
This is absolutely fabulous! Nice job. Question - it doesn't work for "Select Cells Through" and Select Points Through". Is this an oversight, or by design? I am fine if Select Cells/Points Through do not work with the <ctrl> key. |
(0012209) Utkarsh Ayachit (administrator) 2008-06-03 07:38 |
It cannot work for "Select Cells/Points Through" since union of two frustums is not a frustum. The underlying selection mechanism will have to change to take in multiple frustums. |
(0012226) Alan Scott (manager) 2008-06-03 12:32 |
Excellent. Tested client/server. |
2008-04-28 12:42 | Alan Scott | New Issue | |
2008-05-29 13:37 | Berk Geveci | Note Added: 0012151 | |
2008-05-29 13:37 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2008-05-29 13:37 | Berk Geveci | Priority | normal => low |
2008-05-29 13:37 | Berk Geveci | Status | backlog => tabled |
2008-05-30 16:34 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-05-30 16:34 | Utkarsh Ayachit | Resolution | open => fixed |
2008-05-30 16:34 | Utkarsh Ayachit | Note Added: 0012171 | |
2008-06-02 18:53 | Alan Scott | Status | @80@ => @20@ |
2008-06-02 18:53 | Alan Scott | Resolution | fixed => reopened |
2008-06-02 18:53 | Alan Scott | Note Added: 0012191 | |
2008-06-03 07:38 | Utkarsh Ayachit | Status | @20@ => @80@ |
2008-06-03 07:38 | Utkarsh Ayachit | Resolution | reopened => fixed |
2008-06-03 07:38 | Utkarsh Ayachit | Note Added: 0012209 | |
2008-06-03 12:32 | Alan Scott | Status | @80@ => closed |
2008-06-03 12:32 | Alan Scott | Note Added: 0012226 | |
