0006890 | ParaView | (No Category) | public | 2008-04-24 10:47 | 2009-05-13 13:59 | ||||
Priority | normal | Severity | feature | Reproducibility | have not tried | ||||
Summary | 0006890: Box and Sphere clips and slices | ||||||||
Description | The clip and slice filters should work with boxes and spheres. | ||||||||
(0012164) Utkarsh Ayachit (administrator) 2008-05-30 13:40 |
Added sphere widget. Box widget has already been added. /cvsroot/ParaView3/ParaView3/Qt/Components/CMakeLists.txt,v <-- Qt/Components/CMakeLists.txt new revision: 1.144; previous revision: 1.143 /cvsroot/ParaView3/ParaView3/Qt/Components/pq3DWidget.cxx,v <-- Qt/Components/pq3DWidget.cxx new revision: 1.30; previous revision: 1.29 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSphereWidget.cxx,v <-- Qt/Components/pqSphereWidget.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSphereWidget.h,v <-- Qt/Components/pqSphereWidget.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqSphereWidget.ui,v <-- Qt/Components/Resources/UI/pqSphereWidget.ui initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- Servers/ServerManager/Resources/filters.xml new revision: 1.295; previous revision: 1.294 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- Servers/ServerManager/Resources/rendering.xml new revision: 1.297; previous revision: 1.296 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/utilities.xml,v <-- Servers/ServerManager/Resources/utilities.xml new revision: 1.145; previous revision: 1.144 |
(0012195) Alan Scott (manager) 2008-06-02 19:10 |
Is this really correct? * Client/Server * open disk_out_ref.exo, turn all variables on, apply. * clip/ box/ scale = 0.6, 0.6, 0.6, click Inside Out, Apply. Notice how rough the corners and bottom are... |
(0012212) Ken Moreland (manager) 2008-06-03 10:28 |
I'm not saying it's correct, but I do think that has always been the behavior (even in ParaView 2.X). The reason for the rounding off of the corners is that the implementation uses an implicit function of a box to find inside/outside values at the points of each cell. I think if a cell is intersected, it is clipped based on a linear interpolation of the implicit function at the points, which is a pretty poor assumption at the edges and corners of the box. I'm not sure there is an easy way around the problem. |
(0012653) Utkarsh Ayachit (administrator) 2008-07-08 09:47 |
Marking resolved since the original issue referred to by this bug is indeed resolved. Feel free to add another bug if needed for the corner issue. |
(0012682) Alan Scott (manager) 2008-07-09 16:56 |
Tested client/server. There are jagged edges on a box clip. This has been written up as bug number 7300 |
2008-04-24 10:47 | Ken Moreland | New Issue | |
2008-04-24 10:47 | Ken Moreland | Status | backlog => tabled |
2008-04-24 10:47 | Ken Moreland | Assigned To | => Berk Geveci |
2008-05-29 13:27 | Berk Geveci | Assigned To | Berk Geveci => Utkarsh Ayachit |
2008-05-30 13:40 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-05-30 13:40 | Utkarsh Ayachit | Resolution | open => fixed |
2008-05-30 13:40 | Utkarsh Ayachit | Note Added: 0012164 | |
2008-06-02 19:10 | Alan Scott | Status | @80@ => @20@ |
2008-06-02 19:10 | Alan Scott | Resolution | fixed => reopened |
2008-06-02 19:10 | Alan Scott | Note Added: 0012195 | |
2008-06-03 10:28 | Ken Moreland | Note Added: 0012212 | |
2008-07-08 09:47 | Utkarsh Ayachit | Status | @20@ => @80@ |
2008-07-08 09:47 | Utkarsh Ayachit | Resolution | reopened => fixed |
2008-07-08 09:47 | Utkarsh Ayachit | Note Added: 0012653 | |
2008-07-09 16:56 | Alan Scott | Status | @80@ => closed |
2008-07-09 16:56 | Alan Scott | Note Added: 0012682 | |
