0006883 | ParaView | Bug | public | 2008-04-23 12:51 | 2016-08-12 09:57 | ||||
Priority | normal | Severity | feature | Reproducibility | have not tried | ||||
Summary | 0006883: Object Inspector help from plugins | ||||||||
Description | The context sensitive help for sources and filters in the object inspector is helpful. It would be nice if it also worked for plugins. | ||||||||
(0011511) Ken Moreland (manager) 2008-04-23 12:51 |
Qt 4.4 has a new QtHelp module, and it looks we might be able to add content from plugins. In that case, the assistant wouldn't be used anymore, and the help viewer would be just another window in the application. That would allow for viewing html pages embedded in a plugin and things like that. Or it might be possible to create a wrapper that can dynamically create html from server manager xml. |
(0020208) Utkarsh Ayachit (administrator) 2010-04-16 01:50 |
We are now using QtHelp module for online help, so this shouldn't be too daunting. Just determining the API may be tricky. |
(0037569) Kitware Robot (administrator) 2016-08-12 09:57 |
2008-04-23 12:51 | Ken Moreland | New Issue | |
2008-04-23 12:51 | Ken Moreland | Note Added: 0011511 | |
2008-04-23 12:51 | Ken Moreland | Status | backlog => tabled |
2008-04-23 12:51 | Ken Moreland | Assigned To | => Clinton Stimpson |
2009-02-17 16:02 | Ken Moreland | Category | 3.6 => 3.8 |
2009-05-13 13:40 | Utkarsh Ayachit | Target Version | => 3.8 |
2010-01-11 14:09 | Utkarsh Ayachit | Assigned To | Clinton Stimpson => Utkarsh Ayachit |
2010-04-16 01:48 | Utkarsh Ayachit | Category | => Bug |
2010-04-16 01:48 | Utkarsh Ayachit | Target Version | 3.8 => 3.10 |
2010-04-16 01:50 | Utkarsh Ayachit | Note Added: 0020208 | |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037569 | |
