0006880 | ParaView | (No Category) | public | 2008-04-22 18:42 | 2009-05-13 13:59 | ||||
Priority | urgent | Severity | crash | Reproducibility | always | ||||
Summary | 0006880: Extract CTH Boundaries and Fragments crash | ||||||||
Description | There is a crash when using the Extract CTH Boundaries and Fragments filter. * Open ParaView trunk, XP client, client/server. * Open Dave's small CTH example, spcta_a.0. Turn on all cell arrays. Apply. * Extract CTH Boundaries and Fragments, don't enter anything, Apply. Server drops - I have no idea where. This must be fixed for 3.4. | ||||||||
Additional Information | Changing to urgent, since this is keeping us from seeing the CTH fragment problem reported by Lisa. | ||||||||
(0011500) Alan Scott (manager) 2008-04-22 21:58 |
Works with Linux, including Berk's patch. The XP failure, listed above, does NOT have Berk's patch. |
(0011505) Berk Geveci (administrator) 2008-04-23 10:11 |
Which patch are we talking about? Also, can you make sure that you have the latest cvs paraview? There has been changes to that filter. |
(0011514) Alan Scott (manager) 2008-04-23 14:53 |
I just tested it with this morning's CVS. Still fails in the server. Entering Material volume fraction - 1 acts like it is an unknown variable, failing in the server. Top of the output window is as follows: ERROR: In C:\alan\paraviewNightlyTrunk\src\ParaView3\Servers\Common\vtkServerConnection.cxx, line 67 vtkServerConnection (097EBDA8): Server Connection Closed! ERROR: In C:\alan\paraviewNightlyTrunk\src\ParaView3\Servers\Common\vtkServerConnection.cxx, line 351 vtkServerConnection (097EBDA8): Server could failed to gather information. Then, lots of verbose output. By the way, the patch I am talking about is the Exodus Writer patch, sent from Berk to Alan at 3:15 April 21st. alan |
(0011527) Alan Scott (manager) 2008-04-23 21:37 |
We just updated the Linux tree, and this bug is in Linux also. |
(0011538) Berk Geveci (administrator) 2008-04-24 16:56 |
The XML for the new GUI was missing. |
(0011575) Alan Scott (manager) 2008-04-28 17:07 |
Tested client/server. |
2008-04-22 18:42 | Alan Scott | New Issue | |
2008-04-22 19:32 | Alan Scott | Priority | high => urgent |
2008-04-22 19:32 | Alan Scott | Additional Information Updated | |
2008-04-22 21:58 | Alan Scott | Note Added: 0011500 | |
2008-04-23 10:09 | Berk Geveci | Status | backlog => tabled |
2008-04-23 10:09 | Berk Geveci | Assigned To | => Berk Geveci |
2008-04-23 10:11 | Berk Geveci | Note Added: 0011505 | |
2008-04-23 14:53 | Alan Scott | Note Added: 0011514 | |
2008-04-23 21:37 | Alan Scott | Note Added: 0011527 | |
2008-04-24 16:56 | Berk Geveci | Status | tabled => @80@ |
2008-04-24 16:56 | Berk Geveci | Resolution | open => fixed |
2008-04-24 16:56 | Berk Geveci | Note Added: 0011538 | |
2008-04-28 17:07 | Alan Scott | Status | @80@ => closed |
2008-04-28 17:07 | Alan Scott | Note Added: 0011575 | |
