0006806 | ParaView | (No Category) | public | 2008-04-15 09:55 | 2009-05-13 13:59 | ||||
Reporter | Robert Maynard | ||||||||
Platform | Apple Mac | OS | OS X | OS Version | 10.4.10 | ||||
Summary | 0006806: Mulitple Visibility of Pipeline Objects | ||||||||
Description | Finished adding the ability to turn on/off multiple items at a time. Basically it checks that selected list of items when a person clicks on an 'eye' and flips their visibility. Checks are in place to make sure that it only does this if the eye that is selected is inside the selected list, otherwise it operates on the 'eye' only. | ||||||||
Attached Files | mvis.zip [^] (8,631 bytes) 2008-04-15 09:55 vis.zip [^] (8,624 bytes) 2008-04-15 12:52 | ||||||||
(0011330) Robert Maynard (developer) 2008-04-15 11:00 |
After some more testing there seems to be a problem. The code to check if you are inside the selection group fails, when you have more than 1 multiple input in the pipeline. To be more exact when you have selected some parts on multiple Input 1, and then click on a multiple input 2 item, you should only turn on the visibility of multiple input item 2, not 1 (which it is currently doing). |
(0011338) Robert Maynard (developer) 2008-04-15 12:52 |
Fixed the problem with multiple input items |
(0011441) Berk Geveci (administrator) 2008-04-19 15:05 |
Utkarsh: Can you check the patch and apply it if appropriate? Otherwise, please set the target to 3.6. |
(0011451) Utkarsh Ayachit (administrator) 2008-04-21 10:40 |
Committing patch for BUG 0006806 excluding the part for deleting multiple items. /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineBrowser.cxx,v <-- Qt/Components/pqPipelineBrowser.cxx new revision: 1.25; previous revision: 1.24 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineBrowser.h,v <-- Qt/Components/pqPipelineBrowser.h new revision: 1.18; previous revision: 1.17 |
(0011513) Alan Scott (manager) 2008-04-23 14:37 |
Very nice. Tested client/server. |
2008-04-15 09:55 | Robert Maynard | New Issue | |
2008-04-15 09:55 | Robert Maynard | File Added: mvis.zip | |
2008-04-15 11:00 | Robert Maynard | Note Added: 0011330 | |
2008-04-15 12:52 | Robert Maynard | Note Added: 0011338 | |
2008-04-15 12:52 | Robert Maynard | File Added: vis.zip | |
2008-04-19 15:05 | Berk Geveci | Note Added: 0011441 | |
2008-04-19 15:05 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2008-04-19 15:05 | Berk Geveci | Status | backlog => tabled |
2008-04-21 10:40 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-04-21 10:40 | Utkarsh Ayachit | Resolution | open => fixed |
2008-04-21 10:40 | Utkarsh Ayachit | Note Added: 0011451 | |
2008-04-23 14:37 | Alan Scott | Status | @80@ => closed |
2008-04-23 14:37 | Alan Scott | Note Added: 0011513 | |
