0006700 | ParaView | (No Category) | public | 2008-04-01 15:45 | 2009-05-13 13:59 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0006700: Selection bug with multi-blocks | ||||||||
Description | To reproduce: * Load can.ex2 * Turn on all sets and blocks * Rubber-band select -> selection results are wrong | ||||||||
Relationships | ||||||
(0011037) Utkarsh Ayachit (administrator) 2008-04-02 13:40 |
vtkAppendPolyData did not append the cell data correctly. If any of the inputs had different cell types, the output cell data would end up incorrect. This is because the previous implementation did not take into consideration the fact that in polydata, first come all the verts, then lines, and so. Fixed that. /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkAppendPolyData.cxx,v <-- VTK/Graphics/vtkAppendPolyData.cxx new revision: 1.103; previous revision: 1.102 |
(0011128) Alan Scott (manager) 2008-04-07 17:39 |
Tested client/server |
2008-04-01 15:45 | Berk Geveci | New Issue | |
2008-04-01 15:45 | Berk Geveci | Status | backlog => tabled |
2008-04-01 15:45 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2008-04-02 13:40 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-04-02 13:40 | Utkarsh Ayachit | Resolution | open => fixed |
2008-04-02 13:40 | Utkarsh Ayachit | Note Added: 0011037 | |
2008-04-02 13:49 | Clinton Stimpson | Relationship added | has duplicate 0005899 |
2008-04-07 17:39 | Alan Scott | Status | @80@ => closed |
2008-04-07 17:39 | Alan Scott | Note Added: 0011128 | |
2009-05-13 13:58 | Utkarsh Ayachit | Target Version | Multi-block support => 3.4 |
