0006689 | ParaView | (No Category) | public | 2008-04-01 09:32 | 2009-05-13 13:59 | ||||
Assigned To | Alan Scott | ||||||||
Summary | 0006689: Custom filters with no input can never be instantiated | ||||||||
Description | Create a custom filter from a source (say sphere source). It still shows up in the filters menu and is never enabled. | ||||||||
Attached Files | SourceCustomFilter.xml [^] (3,378 bytes) 2008-04-03 11:12 | ||||||||
(0011014) Utkarsh Ayachit (administrator) 2008-04-01 10:47 |
If a custom filter is created with no inputs, then it gets added to the "sources" group and is available in the sources menu. /cvsroot/ParaView3/ParaView3/Qt/Components/pqCustomFilterDefinitionWizard.cxx,v <-- Qt/Components/pqCustomFilterDefinitionWizard.cxx new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Qt/Components/pqCustomFilterManager.cxx,v <-- Qt/Components/pqCustomFilterManager.cxx new revision: 1.8; previous revision: 1.7 |
(0011053) Alan Scott (manager) 2008-04-02 19:09 |
I cannot replicate the fix. This bug seems to be intact to me. Local client, it acts as stated here. Client/Server, it crashes paraview. |
(0011058) Utkarsh Ayachit (administrator) 2008-04-03 11:13 |
Really weird. I tried on linux/vista/builtin/client-server. This seems to work fine for me. Try playing the attached test. Make sure that there's no custom filter named "UDANewSource" before running the test. |
(0011126) Alan Scott (manager) 2008-04-07 17:31 |
Tested local client. If you don't have an input to a custom filter, it goes in the source area. |
2008-04-01 09:32 | Utkarsh Ayachit | New Issue | |
2008-04-01 09:32 | Utkarsh Ayachit | Status | backlog => tabled |
2008-04-01 09:32 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2008-04-01 10:47 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-04-01 10:47 | Utkarsh Ayachit | Resolution | open => fixed |
2008-04-01 10:47 | Utkarsh Ayachit | Note Added: 0011014 | |
2008-04-02 19:09 | Alan Scott | Status | @80@ => @20@ |
2008-04-02 19:09 | Alan Scott | Resolution | fixed => reopened |
2008-04-02 19:09 | Alan Scott | Note Added: 0011053 | |
2008-04-03 11:12 | Utkarsh Ayachit | File Added: SourceCustomFilter.xml | |
2008-04-03 11:13 | Utkarsh Ayachit | Note Added: 0011058 | |
2008-04-03 11:13 | Utkarsh Ayachit | Status | @20@ => tabled |
2008-04-03 11:13 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Alan Scott |
2008-04-03 11:14 | Utkarsh Ayachit | Status | tabled => @20@ |
2008-04-07 17:31 | Alan Scott | Status | @20@ => closed |
2008-04-07 17:31 | Alan Scott | Note Added: 0011126 | |
2008-04-07 17:31 | Alan Scott | Resolution | reopened => fixed |
