0006686 | ParaView | (No Category) | public | 2008-03-31 14:47 | 2009-05-13 13:59 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0006686: Issue with spreadsheet view and multiblocks | ||||||||
Description | When "Show only selected elements" is on, spreadsheet view does not always show selected elements if visualizing multi-block datasets. See Steps to Reproduce. | ||||||||
Steps To Reproduce | * Load can.ex2 * Create spreadsheet view * Turn "Show only selected elements" on * Select a cell -> not always shown in the spreadsheet view | ||||||||
(0011031) Utkarsh Ayachit (administrator) 2008-04-02 10:45 |
Can't reproduce. Can you verify if this is fixed now? Ensure that you are indeed selecting the cells in the block that is currently shown in the spreadsheet view. |
(0011716) Alan Scott (manager) 2008-05-05 19:59 |
This sometimes hangs client/server. To replicate, do the following: 3 server, XP client, linux server. Nightly, May 5th. open can.exo Select cells on - one cell on base. Vertical split, spreadsheet view. Display tab, "Show only selected elements" Once this ended up hung, the other time it just didn't show anything in the spreadsheet view (it should have shown one cell). I had the focus on the spreadsheet, eyeball on. |
(0011721) Berk Geveci (administrator) 2008-05-06 13:46 |
Two new features would fix this problem: * If the current block in the spreadsheet view has not selected elements (and show only selected elements is on), switch to the first block that has anything selected * In the block tree, show the number of selected elements next to the block name |
(0012339) Utkarsh Ayachit (administrator) 2008-06-14 12:39 |
The multi-block structure widget on the display tab for spreadsheet view shows the number of cells/points selected for each block. When in selection only mode, the current block shown changes to the first block which has some selected data. ---------------------------------------------------- commitid: 1Ky2zz2NZbep5W6t; ---------------------------------------------------- /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- Servers/ServerManager/Resources/filters.xml new revision: 1.297; previous revision: 1.296 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSpreadSheetRepresentationProxy.cxx,v <-- Servers/ServerManager/vtkSMSpreadSheetRepresentationProxy.cxx new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMCompositeTreeDomain.h,v <-- Servers/ServerManager/vtkSMCompositeTreeDomain.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMCompositeTreeDomain.cxx,v <-- Servers/ServerManager/vtkSMCompositeTreeDomain.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVExtractSelection.h,v <-- Servers/Filters/vtkPVExtractSelection.h new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/Common/CMakeLists.txt,v <-- Servers/Common/CMakeLists.txt new revision: 1.76; previous revision: 1.75 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVCompositeDataInformationIterator.h,v <-- Servers/Common/vtkPVCompositeDataInformationIterator.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVCompositeDataInformationIterator.cxx,v <-- Servers/Common/vtkPVCompositeDataInformationIterator.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqSpreadSheetViewModel.h,v <-- Qt/Core/pqSpreadSheetViewModel.h new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Qt/Core/pqSpreadSheetView.cxx,v <-- Qt/Core/pqSpreadSheetView.cxx new revision: 1.18; previous revision: 1.17 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqSpreadSheetDisplayEditor.ui,v <-- Qt/Components/Resources/UI/pqSpreadSheetDisplayEditor.ui new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSpreadSheetDisplayEditor.cxx,v <-- Qt/Components/pqSpreadSheetDisplayEditor.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSignalAdaptorCompositeTreeWidget.h,v <-- Qt/Components/pqSignalAdaptorCompositeTreeWidget.h new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSignalAdaptorCompositeTreeWidget.cxx,v <-- Qt/Components/pqSignalAdaptorCompositeTreeWidget.cxx new revision: 1.9; previous revision: 1.8 |
(0012389) Alan Scott (manager) 2008-06-17 18:11 |
Tested client/server |
2008-03-31 14:47 | Berk Geveci | New Issue | |
2008-03-31 14:47 | Berk Geveci | Status | backlog => tabled |
2008-03-31 14:47 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2008-03-31 14:47 | Berk Geveci | Target Version | => Multi-block support |
2008-04-02 10:45 | Utkarsh Ayachit | Note Added: 0011031 | |
2008-04-02 10:45 | Utkarsh Ayachit | Status | tabled => @20@ |
2008-05-01 13:25 | Berk Geveci | Status | @20@ => tabled |
2008-05-01 13:25 | Berk Geveci | Assigned To | Utkarsh Ayachit => Berk Geveci |
2008-05-01 13:26 | Berk Geveci | Status | tabled => @80@ |
2008-05-01 13:26 | Berk Geveci | Resolution | open => fixed |
2008-05-05 19:59 | Alan Scott | Status | @80@ => @20@ |
2008-05-05 19:59 | Alan Scott | Resolution | fixed => reopened |
2008-05-05 19:59 | Alan Scott | Note Added: 0011716 | |
2008-05-06 13:46 | Berk Geveci | Note Added: 0011721 | |
2008-05-06 13:46 | Berk Geveci | Assigned To | Berk Geveci => Utkarsh Ayachit |
2008-05-06 13:46 | Berk Geveci | Status | @20@ => tabled |
2008-06-14 12:39 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-06-14 12:39 | Utkarsh Ayachit | Resolution | reopened => fixed |
2008-06-14 12:39 | Utkarsh Ayachit | Note Added: 0012339 | |
2008-06-17 18:11 | Alan Scott | Status | @80@ => closed |
2008-06-17 18:11 | Alan Scott | Note Added: 0012389 | |
2009-05-13 13:58 | Utkarsh Ayachit | Target Version | Multi-block support => 3.4 |
