0006632 | ParaView | (No Category) | public | 2008-03-20 10:05 | 2009-05-13 13:59 | ||||
Reporter | Berk Geveci | ||||||||
Priority | high | Severity | feature | Reproducibility | have not tried | ||||
Summary | 0006632: Add testing support to the contour widget | ||||||||
Description | I want to be able to write a python test that sets contour values, performs undo/redo and reads the values back from the widget. Currently, this is not possible because I cannot access the values of the widget through python. | ||||||||
(0010910) Clinton Stimpson (developer) 2008-03-25 18:42 |
/cvsroot/ParaView3/ParaView3/Qt/Testing/pqPythonEventSource.cxx,v <-- pqPythonEventSource.cxx new revision: 1.27; previous revision: 1.26 /cvsroot/ParaView3/ParaView3/Qt/Testing/pqPythonEventSource.h,v <-- pqPythonEventSource.h new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSampleScalarWidget.h,v <-- pqSampleScalarWidget.h new revision: 1.8; previous revision: 1.7 You can set the samples by doing something like this QtTesting.setProperty('MainWindow/objectInspectorDock/1pqProxyTabWidget0/qt_tabwidget_stackedwidget/objectInspector/ScrollArea/qt_scrollarea_viewport/PanelArea/Editor/1pqCollapsedGroup1/pqSampleScalarWidget', 'samples', '120;130;140;150') |
2008-03-20 10:05 | Berk Geveci | New Issue | |
2008-03-20 10:05 | Berk Geveci | Status | backlog => tabled |
2008-03-20 10:05 | Berk Geveci | Assigned To | => Clinton Stimpson |
2008-03-25 18:42 | Clinton Stimpson | Status | tabled => closed |
2008-03-25 18:42 | Clinton Stimpson | Note Added: 0010910 | |
2008-03-25 18:42 | Clinton Stimpson | Resolution | open => fixed |
