0006260VTK(No Category)public2008-01-21 06:502016-08-12 09:54
Reportersebos69
Assigned ToDavid Thompson (old)
PrioritynormalSeveritymajorReproducibilityalways
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version
Summary0006260: [PATCH] vtkMeshQuality::TriangleMinAngle() repports wrong value
Description(this is a copy of a mail sent to vtk-users ML, but this mail had no answer)
Hi,
We found a bug in vtk 5.0.3, in the method
vtkMeshQuality::TriangleMinAngle().
the method computes the 3 triangle angles : alpha, beta and gamma, but the
last one is incorrectly computed. I think it computes PI-gamma instead of
gamma. This bug can sometimes result in a minimal angle greater than 60
degrees, which is impossible.
I saw that the class vtkMeshQuality has changed a lot in the current CVS,
but the following patch could come handy for an update of vtk 5.0.3:
RCS file: /cvsroot/VTK/VTK/Graphics/vtkMeshQuality.cxx,v
retrieving revision 1.31
diff -r1.31 vtkMeshQuality.cxx
670c670
< gamma = acos(vtkMath::Dot(a,b) / sqrt(a2 * b2));
> gamma = acos(-vtkMath::Dot(a,b) / sqrt(a2 * b2));
TagsNo tags attached.
Project
Type
-  Notes
(0036944)
Kitware Robot (administrator)
2016-08-12 09:54
Resolving issue as `moved`.
This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page.
- Issue History
2008-01-21 06:50 sebos69 New Issue
2008-02-06 09:32 Jeff Baumes Status backlog => tabled
2008-02-06 09:32 Jeff Baumes Assigned To => David Thompson (old)
2016-08-12 09:54 Kitware Robot Note Added: 0036944
2016-08-12 09:54 Kitware Robot Status expired => closed
2016-08-12 09:54 Kitware Robot Resolution open => moved
Powered by Mantis Bugtracker
