0006204VTK(No Category)public2007-12-27 08:292012-12-12 11:56
ReporterSören Gebbert
Assigned ToDavid Gobbi
PrioritylowSeverityminorReproducibilityalways
StatusclosedResolutionfixed
PlatformIntel 32BitOSSuSE LinuxOS Version9.2
Product Version
Summary0006204: vtkWrapPython produced a segfault while wrapping
DescriptionvtkWrapPython produced a segfault while wrapping class vtkTriCubicHexahedron
(this class is not yet an official component of vtk, it's in the wish list).
Patch:
Index: vtkWrapPython.c
RCS file: /cvsroot/VTK/VTK/Wrapping/vtkWrapPython.c,v
retrieving revision 1.84
diff -u -r1.84 vtkWrapPython.c
--- vtkWrapPython.c 11 Apr 2007 18:11:10 -0000 1.84
+++ vtkWrapPython.c 27 Dec 2007 13:15:45 -0000
@@ -381,7 +381,8 @@
 char *get_format_string()
- static char result[1024];
+ static char result[10240];//Soeren Gebbert 27.12.2007 this field must be enlarged to process the vtkTriCubicHexahedron class
   int currPos = 0;
   int argtype;
   int i, j;
@@ -501,7 +502,7 @@
 void get_python_signature()
+ static char result[10240]; //Soeren Gebbert 27.12.2007 this field must be enlarged to process the vtkTriCubicHexahedron class
   int currPos = 0;
   int argtype;
   int i, j;
Steps To ReproduceIn the build directory VTK_build_shared:
valgrind --tool=memcheck bin/vtkWrapPython /1/gebbert/VTK/Filtering/vtkTriCubicHexahedron.h /1/gebbert/VTK/Wrapping/hints 1 /1/gebbert/VTK_build_shared/Filtering/vtkTriCubicHexahedronPython.cxx
TagsNo tags attached.
Project
Type
Attached Filespatch file icon vtkWrapPython.patch [^] (809 bytes) 2007-12-27 08:31 [Show Content]
 Relationships
  Notes
(0029873)
David Gobbi (developer)
2012-12-12 11:56
The format string array size has been doubled from 1024 to 2048. Eventually all static string storage in vtkWrapPython should be replaced by dynamic string storage.
 Issue History
2007-12-27 08:29 Sören Gebbert New Issue
2007-12-27 08:31 Sören Gebbert File Added: vtkWrapPython.patch
2008-08-29 16:31 David Cole Status backlog => tabled
2008-08-29 16:31 David Cole Assigned To => David Cole
2011-01-19 09:45 David Cole Assigned To David Cole => David Partyka
2011-02-16 15:47 David Gobbi Assigned To David Partyka => David Gobbi
2011-02-26 09:42 David Gobbi Status tabled => @80@
2011-02-26 09:42 David Gobbi Resolution open => fixed
2012-12-12 11:56 David Gobbi Note Added: 0029873
2012-12-12 11:56 David Gobbi Status customer review => closed
