0006111ParaView(No Category)public2007-12-03 11:502009-05-13 13:59
ReporterKen Moreland
Assigned ToKen Moreland
StatusclosedResolutionduplicate
PlatformOSOS Version
Product Version
Target Version3.4Fixed in Version3.4
Summary0006111: Colors in histogram go bad after changing variable
DescriptionIf you change the scalar on which you make a histogram, the colors sometimes go funny in the bar chart. To replicate, do the following.
1. Load disk_out_ref.ex2 with all of the variables on.
2. Create a histogram on the Temp variable. The bar chart that is created has the correct coloring.
3. In the Properties panel of the histogram, change the scalars option from Temp to Pres and apply. In the bar chart, the all the bars look blue instead of the expected mapping.
4. In the Properties panel of the histogram, change the scalars option back to Temp. Now the colors are wrong again. This time they all look red.
You can get back the correct coloring by turning the visibility of the histogram in the bar chart view off and then back on.
TagsNo tags attached.
Project
Topic Name
Type
duplicate of 0005966closedMark Richardson coloring problems when changing array for computing histogram
-  Notes
(0011191)
Alan Scott (manager)
2008-04-08 18:01
Duplicate.
- Issue History
2007-12-03 11:50 Ken Moreland New Issue
2008-04-08 15:20 Ken Moreland Relationship added duplicate of 0005966
2008-04-08 15:20 Ken Moreland Duplicate ID 0 => 5966
2008-04-08 15:20 Ken Moreland Status backlog => @80@
2008-04-08 15:20 Ken Moreland Resolution open => duplicate
2008-04-08 15:20 Ken Moreland Assigned To => Ken Moreland
2008-04-08 18:01 Alan Scott Status @80@ => closed
2008-04-08 18:01 Alan Scott Note Added: 0011191
2009-05-13 13:58 Utkarsh Ayachit Target Version => 3.4
2009-05-13 13:59 Utkarsh Ayachit Fixed in Version => 3.4
Powered by Mantis Bugtracker
