0006109 | ParaView | (No Category) | public | 2007-12-03 09:29 | 2009-05-13 13:59 | ||||
Summary | 0006109: Cannot change bar chart colors in its display panel | ||||||||
Description | There is no direct way to change the colors in a bar chart. You should be able to go to the display panel with the bar chart and visible object active and edit the color map. | ||||||||
Additional Information | You can get around this problem by going to a 3D view showing the same variable and change the colors for the 3D view. | ||||||||
Relationships | |||||||||||
(0012990) Mark Richardson (reporter) 2008-08-12 13:58 |
The edit color map button on the bar chart display panel now works. I added a virtual method to pqDataRepresentation to get the opacity function. That abstraction simplified the color map editor. I also removed the component selection combo box from the color map editor, which made it possible to edit a pipeline and a bar chart representation in the same dialog. The histogram color map can be edited from the toolbar button as well. |
(0013020) Alan Scott (manager) 2008-08-14 16:15 |
Tested client/server. |
2007-12-03 09:29 | Ken Moreland | New Issue | |
2008-01-14 12:30 | Ken Moreland | Relationship added | related to 0006239 |
2008-04-08 15:13 | Ken Moreland | Relationship added | has duplicate 0005955 |
2008-04-08 15:18 | Ken Moreland | Status | backlog => tabled |
2008-04-08 15:18 | Ken Moreland | Assigned To | => Berk Geveci |
2008-05-01 13:48 | Berk Geveci | Assigned To | Berk Geveci => Mark Richardson |
2008-08-12 13:58 | Mark Richardson | Status | tabled => @80@ |
2008-08-12 13:58 | Mark Richardson | Resolution | open => fixed |
2008-08-12 13:58 | Mark Richardson | Note Added: 0012990 | |
2008-08-14 16:15 | Alan Scott | Status | @80@ => closed |
2008-08-14 16:15 | Alan Scott | Note Added: 0013020 | |
