0006090 | ParaView | (No Category) | public | 2007-11-28 11:19 | 2009-05-13 13:59 | ||||
Summary | 0006090: Color editing from toolbar | ||||||||
Description | The Active Variable Controls and Representation toolbars have saved me a lot of time by preventing me from having to switch to and from the display panel. However, I find I still have to go to this panel somewhat frequently to change the colors. I think I could avoid going to the Display panel 90% of the time if the following two icons were added to the Active Variable Controls toolbar: 1. A button that is equivalent to hitting the Edit Color Map button in the Display panel. If a solid color is being displayed, then it should be equivalent to the Set Solid Color button. 2. A button that is equivalent to hitting Rescale to Data Range (grayed out when showing a solid color). It would also be cool if the toggle color visibility or edit color map button had a pulldown menu that allowed you to select one of color scale presents. You could also put one or both of the above options into that pulldown. | ||||||||
(0011740) Mark Richardson (reporter) 2008-05-07 17:01 |
I added two toolbar buttons. One to rescale to the data range. One to either set the solid color or edit the color map. |
(0011841) Alan Scott (manager) 2008-05-12 17:56 |
Wwow, that is nice!! Tested client/server. |
2007-11-28 11:19 | Ken Moreland | New Issue | |
2008-04-08 14:43 | Ken Moreland | Status | backlog => tabled |
2008-04-08 14:43 | Ken Moreland | Assigned To | => Berk Geveci |
2008-05-01 13:45 | Berk Geveci | Assigned To | Berk Geveci => Clinton Stimpson |
2008-05-01 13:45 | Berk Geveci | Assigned To | Clinton Stimpson => Mark Richardson |
2008-05-07 17:01 | Mark Richardson | Status | tabled => @80@ |
2008-05-07 17:01 | Mark Richardson | Resolution | open => fixed |
2008-05-07 17:01 | Mark Richardson | Note Added: 0011740 | |
2008-05-12 17:56 | Alan Scott | Status | @80@ => closed |
2008-05-12 17:56 | Alan Scott | Note Added: 0011841 | |
