0005966 | ParaView | (No Category) | public | 2007-10-26 10:34 | 2009-05-13 13:59 | ||||
Reporter | Amy Squillacote | ||||||||
Summary | 0005966: coloring problems when changing array for computing histogram | ||||||||
Description | This is a problem both on ParaView 3.2 and in the development version. First load a dataset with multiple arrays (can.ex2 is fine). Apply the histogram filter to it. Change the array being used to compute the histogram, and click Apply. Assuming that the newly-selected array has a different range than the original array, the coloring of the updated histogram will be wrong. In many cases, the new histogram will be a solid color. If the original array was point-centered, then if you choose a cell-centered one, the coloring looks correct, but any subsequently select cell arrays will produce incorrectly-colored histograms until a point-centered one is chosen. | ||||||||
Relationships | ||||||
(0011170) Ken Moreland (manager) 2008-04-08 15:20 |
You can get back the correct coloring by turning the visibility of the histogram in the bar chart view off and then back on. |
(0011670) Mark Richardson (reporter) 2008-05-01 18:41 |
I put in a one line quick fix for this. The histogram coloring now changes with the array change. |
(0011831) Alan Scott (manager) 2008-05-12 16:57 |
I believe this one works. Tested client/server. |
2007-10-26 10:34 | Amy Squillacote | New Issue | |
2008-04-07 19:06 | Ken Moreland | Status | backlog => tabled |
2008-04-07 19:06 | Ken Moreland | Assigned To | => Clinton Stimpson |
2008-04-07 19:06 | Ken Moreland | Category | => 3.4 |
2008-04-08 15:20 | Ken Moreland | Relationship added | has duplicate 0006111 |
2008-04-08 15:20 | Ken Moreland | Note Added: 0011170 | |
2008-04-16 16:26 | Clinton Stimpson | Assigned To | Clinton Stimpson => Mark Richardson |
2008-05-01 18:41 | Mark Richardson | Status | tabled => @80@ |
2008-05-01 18:41 | Mark Richardson | Resolution | open => fixed |
2008-05-01 18:41 | Mark Richardson | Note Added: 0011670 | |
2008-05-12 16:57 | Alan Scott | Status | @80@ => closed |
2008-05-12 16:57 | Alan Scott | Note Added: 0011831 | |
