0005895 | ParaView | (No Category) | public | 2007-10-17 14:49 | 2008-01-03 18:46 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0005895: It should be possible to save high resolution images | ||||||||
Description | Save screenshot should support higher resolution that what is on the screen. | ||||||||
(0010023) Utkarsh Ayachit (administrator) 2007-12-26 15:44 |
Partially fixes BUG 0005895. Save screenshot popups a dialog offerring the user to choose the size of the saved image. Need to fix for saving pdfs and for non-render views. /cvsroot/ParaView3/ParaView3/Qt/Components/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.129; previous revision: 1.128 /cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationManager.cxx,v <-- pqAnimationManager.cxx new revision: 1.27; previous revision: 1.26 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- pqMainWindowCore.cxx new revision: 1.242; previous revision: 1.241 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.h,v <-- pqMainWindowCore.h new revision: 1.86; previous revision: 1.85 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSaveSnapshotDialog.cxx,v <-- pqSaveSnapshotDialog.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSaveSnapshotDialog.h,v <-- pqSaveSnapshotDialog.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqSaveSnapshotDialog.ui,v <-- pqSaveSnapshotDialog.ui initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderView.cxx,v <-- pqRenderView.cxx new revision: 1.28; previous revision: 1.27 /cvsroot/ParaView3/ParaView3/Qt/Core/pqView.cxx,v <-- pqView.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Core/pqView.h,v <-- pqView.h new revision: 1.10; previous revision: 1.9 |
(0010024) Utkarsh Ayachit (administrator) 2007-12-27 11:03 |
Fixes for BUG 0005895 and BUG 0005894. Added support to save screenshot of all views. Plot views also correctly save high resimages (except pdf) via screenshot as well as when saving animation. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMAnimationSceneImageWriter.h,v <-- vtkSMAnimationSceneImageWriter.h new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationManager.cxx,v <-- pqAnimationManager.cxx new revision: 1.28; previous revision: 1.27 /cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationManager.h,v <-- pqAnimationManager.h new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- pqMainWindowCore.cxx new revision: 1.243; previous revision: 1.242 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSaveSnapshotDialog.cxx,v <-- pqSaveSnapshotDialog.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSaveSnapshotDialog.h,v <-- pqSaveSnapshotDialog.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqViewManager.cxx,v <-- pqViewManager.cxx new revision: 1.50; previous revision: 1.49 /cvsroot/ParaView3/ParaView3/Qt/Components/pqViewManager.h,v <-- pqViewManager.h new revision: 1.18; previous revision: 1.17 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqSaveSnapshotDialog.ui,v <-- pqSaveSnapshotDialog.ui new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPlotView.cxx,v <-- pqPlotView.cxx new revision: 1.19; previous revision: 1.18 |
(0010067) Alan Scott (manager) 2008-01-03 18:46 |
Tested client/server. Trunk. |
2007-10-17 14:49 | Berk Geveci | New Issue | |
2007-10-17 14:49 | Berk Geveci | Status | backlog => tabled |
2007-10-17 14:49 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2007-12-26 15:44 | Utkarsh Ayachit | Note Added: 0010023 | |
2007-12-27 11:03 | Utkarsh Ayachit | Note Added: 0010024 | |
2007-12-28 11:15 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-12-28 11:15 | Utkarsh Ayachit | Resolution | open => fixed |
2008-01-03 18:46 | Alan Scott | Status | @80@ => closed |
2008-01-03 18:46 | Alan Scott | Note Added: 0010067 | |
