0005863 | ParaView | (No Category) | public | 2007-10-10 16:36 | 2015-01-02 10:45 | ||||
Reporter | Dave DeMarle | ||||||||
Target Version | Someday | Fixed in Version | 4.3 | ||||||
Summary | 0005863: Time Source filter does not correctly report its temporal extent in the information page | ||||||||
Description | This filter can produce data over either a continuous range or at discrete time values. In either case the range is from t=0.0 to t=1.0. However the information tab for this filter does not show the available time range. The fix is probably to split the source into a continuous source and a discrete source so that when request information is initially called (before accept) it knows what type of time range it needs to give for the info page to use. | ||||||||
Additional Information | /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMTimeStepsInformationHelper.cxx,v <-- vtkSMTimeStepsInformationHelper.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/sources.xml,v <-- sources.xml new revision: 1.76; previous revision: 1.75 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkTimeSourceExample.cxx,v <-- vtkTimeSourceExample.cxx new revision: 1.5; previous revision: 1.4 | ||||||||
(0009502) Alan Scott (manager) 2007-10-17 17:03 |
Should this be in the 3.2 branch? I don't see it there... |
(0033624) Cory Quammen (developer) 2014-10-10 10:29 |
This no longer appears to be an issue. The time steps are reported correctly in the table that shows the time step index and time value. |
(0033647) Utkarsh Ayachit (administrator) 2014-10-15 10:08 |
Topics merged into master: 15025_fix_annotations 15035_reverse_connections_dsrs 15043_add_qmake_variable_back 15044_update_example_plugins cmake-cmp0053-warnings live-breakpoint pv-plot-bar-lut visible_range |
(0033774) Alan Scott (manager) 2014-11-06 20:19 |
Tested master, Linux, local server. |
2007-10-10 16:36 | Dave DeMarle | New Issue | |
2007-10-11 13:17 | Dave DeMarle | Status | backlog => tabled |
2007-10-11 13:17 | Dave DeMarle | Assigned To | => Dave DeMarle |
2007-10-15 14:49 | Dave DeMarle | Status | tabled => @80@ |
2007-10-15 14:49 | Dave DeMarle | Additional Information Updated | |
2007-10-17 17:03 | Alan Scott | Status | @80@ => @20@ |
2007-10-17 17:03 | Alan Scott | Resolution | open => reopened |
2007-10-17 17:03 | Alan Scott | Note Added: 0009502 | |
2008-04-15 10:33 | Berk Geveci | Assigned To | Dave DeMarle => Berk Geveci |
2008-04-15 10:33 | Berk Geveci | Status | @20@ => tabled |
2008-04-15 10:33 | Berk Geveci | Category | => Someday |
2009-05-13 13:49 | Utkarsh Ayachit | Target Version | => Someday |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
2014-10-10 10:29 | Cory Quammen | Note Added: 0033624 | |
2014-10-10 10:29 | Cory Quammen | Status | backlog => gatekeeper review |
2014-10-10 10:29 | Cory Quammen | Resolution | reopened => no change required |
2014-10-15 10:08 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-10-15 10:08 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-10-15 10:08 | Utkarsh Ayachit | Note Added: 0033647 | |
2014-11-06 20:19 | Alan Scott | Note Added: 0033774 | |
2014-11-06 20:19 | Alan Scott | Status | customer review => closed |
2015-01-02 10:45 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
