0005850 | ParaView | (No Category) | public | 2007-10-09 19:55 | 2009-05-13 13:46 | ||||
Reporter | Jon Goldman | ||||||||
Assigned To | Jeff Baumes | ||||||||
Summary | 0005850: CSV files with blank lines or lines with whitespace cause problems; data does not plot | ||||||||
Description | When there are blank lines in a CSV file the following type or warning pops up: Warning: In ..\..\..\..\src\ParaView_srcs\ParaView-3-2-tag\ParaView3\Servers\Filters\vtkCSVReader.cxx, line 369 vtkCSVReader (0AE0F158): Igoring column "V(DA_VIDEO_DIG)" since it does not have enough values for cell data. And none of the data is visible in plots or spreadsheet view ParaView3 should ignore "whitespace" lines, or at least WARN the user | ||||||||
(0011327) Berk Geveci (administrator) 2008-04-15 10:27 |
Delaying until after the new chart support. |
(0015296) Jeff Baumes (administrator) 2009-02-23 14:18 |
vtkDelimitedTextReader now skips empty lines and lines containing only whitespace. This was fixed in the following commit: /cvsroot/VTK/VTK/Infovis/Testing/Cxx/TestDelimitedTextReader.cxx,v <-- Infovis/Testing/Cxx/TestDelimitedTextReader.cxx new revision: 1.14; previous revision: 1.13 /cvsroot/VTK/VTK/Infovis/vtkDelimitedTextReader.cxx,v <-- Infovis/vtkDelimitedTextReader.cxx new revision: 1.24; previous revision: 1.23 |
(0015325) Jeff Baumes (administrator) 2009-02-24 09:27 |
Changing back to "resolved" instead of closed. |
(0015358) Alan Scott (manager) 2009-02-24 20:43 |
Excellent. tested client/remote server. |
2007-10-09 19:55 | Jon Goldman | New Issue | |
2008-04-15 10:27 | Berk Geveci | Note Added: 0011327 | |
2008-04-15 10:27 | Berk Geveci | Status | backlog => @30@ |
2008-04-15 10:27 | Berk Geveci | Category | => 3.6 |
2009-02-19 13:53 | Utkarsh Ayachit | Status | @30@ => tabled |
2009-02-19 13:53 | Utkarsh Ayachit | Assigned To | => Jeff Baumes |
2009-02-23 14:18 | Jeff Baumes | Note Added: 0015296 | |
2009-02-23 14:18 | Jeff Baumes | Status | tabled => closed |
2009-02-23 14:18 | Jeff Baumes | Resolution | open => fixed |
2009-02-24 09:27 | Jeff Baumes | Note Added: 0015325 | |
2009-02-24 09:27 | Jeff Baumes | Status | closed => @80@ |
2009-02-24 20:43 | Alan Scott | Note Added: 0015358 | |
2009-02-24 20:43 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
