0005815VTK(No Category)public2007-10-02 04:582014-02-18 08:57
Reporterxabi riobe
Assigned ToDave DeMarle
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target VersionFixed in Version6.2.0
Summary0005815: memory leak when failing to write with vtkPNGWriter
DescriptionThere are some memory leaks if a vtkPNGWriter fails to write a file if we are out of disk space.
Here comes a diff patch to avoid this:
@@ -198,6 +198,8 @@
   this->TempFP = 0;
+ png_byte **row_pointers;
   if (this->WriteToMemory)
     vtkUnsignedCharArray *uc = this->GetResult();
@@ -227,6 +229,9 @@
       if (setjmp(png_ptr->jmpbuf))
         fclose(this->TempFP);
+ if(row_pointers)
+ delete [] row_pointers;
+ png_destroy_write_struct(&png_ptr, &info_ptr);
         this->SetErrorCode(vtkErrorCode::OutOfDiskSpaceError);
         return;
@@ -272,7 +277,7 @@
     png_set_swap(png_ptr);
 #endif
- png_byte **row_pointers = new png_byte *[height];
+ row_pointers = new png_byte *[height];
   vtkIdType *outInc = data->GetIncrements();
   vtkIdType rowInc = outInc[1]*bit_depth/8;
   for (ui = 0; ui < height; ui++)
TagsNo tags attached.
ProjectTBD
Typeincorrect functionality
 Relationships
  Notes
(0031300)
Dave DeMarle (administrator)
2013-07-22 20:33
Dave P no longer works on the project. If these old issues still exist in 6.0.0, reopen them and assign to Dave DeMarle
(0031659)
xabi riobe (reporter)
2013-09-30 08:41
The issue is still present in 6.0.0
(0031667)
2013-09-30 09:36
http://review.source.kitware.com/#/t/3344 [^]
(0031940)
2013-12-16 11:36
problems in gerrit, reverting to backlog until after 6.1
(0032345)
2014-02-18 08:57
http://review.source.kitware.com/#/t/3344/ [^]
 Issue History
2007-10-02 04:58 xabi riobe New Issue
2008-08-29 17:23 David Cole Status backlog => tabled
2008-08-29 17:23 David Cole Assigned To => David Cole
2011-01-19 09:45 David Cole Assigned To David Cole => David Partyka
2013-07-22 20:33 Dave DeMarle Status backlog => expired
2013-07-22 20:33 Dave DeMarle Note Added: 0031300
2013-09-30 08:41 xabi riobe Note Added: 0031659
2013-09-30 08:41 xabi riobe Status expired => backlog
2013-09-30 08:41 xabi riobe Resolution open => reopened
2013-09-30 09:36 xabi riobe Note Added: 0031667
2013-09-30 09:36 xabi riobe Status backlog => gerrit review
2013-12-16 11:36 Dave DeMarle Project => TBD
2013-12-16 11:36 Dave DeMarle Type => incorrect functionality
2013-12-16 11:36 Dave DeMarle Note Added: 0031940
2013-12-16 11:36 Dave DeMarle Assigned To David Partyka => Dave DeMarle
2013-12-16 11:36 Dave DeMarle Status gerrit review => backlog
2014-01-14 05:52 xabi riobe Status backlog => gerrit review
2014-02-18 08:57 Dave DeMarle Note Added: 0032345
2014-02-18 08:57 Dave DeMarle Status gerrit review => closed
2014-02-18 08:57 Dave DeMarle Resolution reopened => fixed
2014-02-18 08:57 Dave DeMarle Fixed in Version => 6.2.0
