0005778 | ParaView | (No Category) | public | 2007-09-25 12:43 | 2009-05-13 13:59 | ||||
Reporter | Clinton Stimpson | ||||||||
Assigned To | Alan Scott | ||||||||
Summary | 0005778: exodus reader not silent in CanReadFile() | ||||||||
Description | Two problems in vtkExodusIIReader::CanReadFile() Open ParaViewData/Data/SPCTH/spcth.0 and I get Warning: In /.../ParaView3/VTK/Hybrid/vtkExodusIIReader.cxx, line 5910 vtkPExodusIIReader (0x18152c0): Unable to close ".../ParaViewData/Data/SPCTH/spcth.0" opened for testing. Create an empty file touch junk.0 (that's the number zero) Try opening it in paraview and it asserts down inside the call to ex_open(). | ||||||||
(0009292) Clinton Stimpson (developer) 2007-09-25 17:45 |
It still asserts on an empty file. |
(0012083) Alan Scott (manager) 2008-05-22 21:52 |
(0012085) David Thompson (old) (reporter) 2008-05-22 23:19 |
Alan, this is not a bug in VTK's exodus reader but a bug in ex_open. Well, actually, it's a bug in the netcdf function that ex_open calls. There's nothing I could possibly do about it except call stat() on every file before opening it. But that would slow things down and is really just a hack. Either that check should be in ex_open or in ncio_spx_get. Could you file a bug with the Exodus or netcdf folks to fix the problem? |
(0012095) Alan Scott (manager) 2008-05-23 13:44 |
I am marking this closed. * First issue seems to be fixed. Tested client/server. * Second issue, as per Dave (notes below) is not in ParaView or VTK, and would create performance degradations attempting a work around. |
2007-09-25 12:43 | Clinton Stimpson | New Issue | |
2007-09-25 15:09 | Utkarsh Ayachit | Status | backlog => tabled |
2007-09-25 15:09 | Utkarsh Ayachit | Assigned To | => Eric Stanton |
2007-09-25 17:40 | Eric Stanton | Status | tabled => @80@ |
2007-09-25 17:40 | Eric Stanton | Resolution | open => fixed |
2007-09-25 17:45 | Clinton Stimpson | Status | @80@ => @20@ |
2007-09-25 17:45 | Clinton Stimpson | Resolution | fixed => reopened |
2007-09-25 17:45 | Clinton Stimpson | Note Added: 0009292 | |
2008-04-15 10:10 | Berk Geveci | Assigned To | Eric Stanton => David Thompson (old) |
2008-04-15 10:10 | Berk Geveci | Status | @20@ => tabled |
2008-04-15 10:10 | Berk Geveci | Category | => 3.4 |
2008-04-15 10:10 | Berk Geveci | Description Updated | |
2008-05-22 13:52 | Berk Geveci | Status | tabled => @80@ |
2008-05-22 13:52 | Berk Geveci | Resolution | reopened => fixed |
2008-05-22 21:52 | Alan Scott | Status | @80@ => @20@ |
2008-05-22 21:52 | Alan Scott | Resolution | fixed => reopened |
2008-05-22 21:52 | Alan Scott | Note Added: 0012083 | |
2008-05-22 23:15 | David Thompson (old) | Status | @20@ => tabled |
2008-05-22 23:15 | David Thompson (old) | Assigned To | David Thompson (old) => Alan Scott |
2008-05-22 23:19 | David Thompson (old) | Note Added: 0012085 | |
2008-05-23 13:44 | Alan Scott | Status | tabled => closed |
2008-05-23 13:44 | Alan Scott | Note Added: 0012095 | |
2008-05-23 13:44 | Alan Scott | Resolution | reopened => fixed |
