0005708 | ParaView | Bug | public | 2007-09-13 17:52 | 2016-08-12 09:57 | ||||
Reporter | Clinton Stimpson | ||||||||
Target Version | Someday | Fixed in Version | |||||||
Summary | 0005708: cutting plane disappears | ||||||||
Description | create a sphere apply the clip filter rotate the view a touch so you can get to the plane move the plane back to the end of the box until it disappears, and let go of the mouse button. You can get the plane back unless you move an arrow head/tail to expose part of it or use the GUI panel. It would be nice if the plane never disappeared. | ||||||||
(0011324) Berk Geveci (administrator) 2008-04-15 09:50 |
We need to take the 3d widgets into account when computing clipping planes. |
(0011347) Utkarsh Ayachit (administrator) 2008-04-15 15:56 |
Widget bounds are now taken into consideration wehn computing clipping planes. However this bug is not due to the clipping planes, but the vtkImplicitPlaneRepresentation itself not showing the plane. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMNewWidgetRepresentationProxy.cxx,v <-- Servers/ServerManager/vtkSMNewWidgetRepresentationProxy.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMNewWidgetRepresentationProxy.h,v <-- Servers/ServerManager/vtkSMNewWidgetRepresentationProxy.h new revision: 1.7; previous revision: 1.6 |
(0011457) Utkarsh Ayachit (administrator) 2008-04-21 11:57 |
Changing to 3.6 since the bug in the vtk widget. |
(0037539) Kitware Robot (administrator) 2016-08-12 09:57 |
2007-09-13 17:52 | Clinton Stimpson | New Issue | |
2008-04-15 09:50 | Berk Geveci | Note Added: 0011324 | |
2008-04-15 09:50 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2008-04-15 09:50 | Berk Geveci | Status | backlog => tabled |
2008-04-15 09:50 | Berk Geveci | Category | => 3.4 |
2008-04-15 15:56 | Utkarsh Ayachit | Note Added: 0011347 | |
2008-04-21 11:57 | Utkarsh Ayachit | Note Added: 0011457 | |
2008-04-21 11:57 | Utkarsh Ayachit | Category | 3.4 => 3.6 |
2009-02-16 16:21 | Ken Moreland | Category | 3.6 => 3.8 |
2009-05-13 13:41 | Utkarsh Ayachit | Target Version | => 3.8 |
2009-12-01 17:13 | Utkarsh Ayachit | Category | => Bug |
2009-12-01 17:13 | Utkarsh Ayachit | Fixed in Version | => Someday |
2010-04-16 02:08 | Utkarsh Ayachit | Fixed in Version | Someday => |
2010-04-16 02:08 | Utkarsh Ayachit | Target Version | 3.8 => Someday |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037539 | |
