0005659ParaViewBugpublic2007-09-05 23:202016-08-12 09:59
ReporterAlan Scott
Assigned ToDan Lipsa
PrioritynormalSeveritymajorReproducibilityalways
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version
Target Version5.1Fixed in Version
Summary0005659: Glyph filter scale factor starts wrong
DescriptionStart ParaView, open can.exo, turn on all variables, Apply.
Glyph filter. Apply. Turn can so you can see it.
Play.
Within a few frames, the vector lengths are wrong. This is another case of the data ranges not being correct for all time. Frankly, I don't know what the correct answer is.
Turn the "arrows" around so you can see them.
TagsNo tags attached.
ProjectSandia
Topic Name
Typeincorrect functionality
related to 0008964closedUtkarsh Ayachit Bad default glyph size
-  Notes
(0025131)
2011-01-28 13:43
This can be supported in the Glyph filter itself. We can have an "auto-scale" mode on the glyph filter where it determines the scale factor for each timestep automatically using the data and glyph-source bounds.
(0025136)
Alan Scott (manager)
2011-01-28 13:55
That would be excellent.
(0035410)
Dan Lipsa (developer)
2015-11-04 13:48
https://gitlab.kitware.com/paraview/paraview/merge_requests/460 [^]
(0038083)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
- Issue History
2007-09-05 23:20 Alan Scott New Issue
2008-04-15 09:40 Berk Geveci Status backlog => @30@
2008-04-15 09:40 Berk Geveci Category => Someday
2008-04-15 09:40 Berk Geveci Description Updated
2009-05-13 13:49 Utkarsh Ayachit Target Version => Someday
2009-06-03 20:34 Alan Scott Relationship added related to 0008964
2009-06-03 22:02 Alan Scott Category => Bug
2009-06-03 22:02 Alan Scott Target Version Someday => 3.8
2011-01-28 13:43 Utkarsh Ayachit Note Added: 0025131
2011-01-28 13:44 Utkarsh Ayachit Target Version 3.8 => 4.0
2011-01-28 13:55 Alan Scott Note Added: 0025136
2011-09-01 10:56 Utkarsh Ayachit Project => Sandia
2015-10-23 10:19 Utkarsh Ayachit Assigned To => Dan Lipsa
2015-10-23 10:20 Utkarsh Ayachit Type => incorrect functionality
2015-10-23 10:20 Utkarsh Ayachit Target Version => 5.0
2015-10-23 11:18 Dan Lipsa Status backlog => active development
2015-11-04 13:48 Dan Lipsa Note Added: 0035410
2016-01-08 15:31 Utkarsh Ayachit Target Version 5.0 => 5.1
2016-08-12 09:59 Kitware Robot Note Added: 0038083
2016-08-12 09:59 Kitware Robot Status active development => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
Powered by Mantis Bugtracker
